Announcement
No announcement yet.
BartPE - Burn test not running
  • Filter
  • BartPE - Burn test not running
    I have searched the forum and i cant seem to find anyone who is having the same issue.
    I followed the guide, configured bartPE and made a cd.
    BartPE Boots fine, burn in test fails to run. no error message, nothing.
    Any ideas?
    Regards, Tom
  • #2
    The document covers installing BurnInTest to run from GO-> Programs->BurnInTest, rather than automatically running on boot.
    - Do you see the GO-> Programs->BurnInTest once you boot into BartPE (this should be installed from step 12 of the BIT_BARTPE document)?
    - Once you boot into BartPE, is there a directory X:\Program files\BurnInTest (this should be installed from step 14 of the BIT_BARTPE document)?
    - Are there any errors reported when you do the BartPE build, step 15.
    - Which Operating System are you using, e.g. 32-bit XP SP3?
    - Which Version of BurnInTest are you using, e.g. 32-bit V6.0.1026 BurnInTest Pro?
    The latest document describing the installing of BartPE with BurnInTest is here:
    http://www.passmark.com/ftp/BIT_BartPE_v6.0.pdf
