serial port test problem, is it a bug ?
  • realmadrid
    • Apr 2007
    I bought a copy of burnintest linux version several weeks ago,my Order Number: U22175318
    I do more test for serial port using burnintest linux, I have found more problems
    the first problem I have wrote a email to help@passmark.com, I can not save serial port test configuration to cfg file, I choose 'detect test only and save to a cfg file", but when I restart and load the cfg file again, the configuration turn back to" detect and loopback test",
    the second problem is the serial port can not run as I wanted, for example I choose " detect test only" and start to run, but the program still run as " detect and loopback test" .
    by the way , I have changed all the file to " 777" privilege and do all the test as "root", I do the test under kunbuntu 6.10 and kubuntu7.04, the same erros occur
    please find a way to solve these problems , thanks
    We are looking into what could be causing this. If anyone else has seen this issue could you please let us know.
    ** Update **
    It seems this was a misunderstanding with how the configuration options were displayed and not a bug.
