Feature Request ACPI temperature control
  • malte
    • Aug 2006
    • 43
    Hi there,
    this is a feature request for BurnIn Test.
    It would be very helpful if BIT can support ACPI temperature monitoring, as this technology is used on most current availabel laptops. It's possible to use it without installing any other control software before.
    Similar to this peace of software, it also controls battery: http://www.pbus-167.com/chc.htm
    Regards
    Malte
    We will add this to our candidate feature list for a future version of BurnInTest. I can not give you an indication of timescale.
    Thanks.
    Ian
    • malte
      • Aug 2006
      • 43
      Hi Ian,
      sounds good so far. What are the general plans for next release of BIT? When will there be the next update?
      Malte
        The next update will improve the network tests (see http://www.passmark.com/forum/showth...p?t=704&page=2). This is planned for release in a couple of weeks.
        I do not have a date for a release with the change you requested.
        Ian
