Initiate BurnInTest from a remote location
  • Anonymous
    • 286
    Is there a slicker way to initiate a test remotely on a network than using scheduler or the "at" command with command line arguments?
    • 11114
    Have you thought of a product like PC-Anywhere to control the PC from a remote station?
    Maybe if you tell us a little bit moore about the circumstances we might have a better suggestion. How 'remote' is the other PC. Is it on the other side of the country or just in a EMI test chamber (for example) ?
    I would think that there must also be a better 3rd product for starting applications on a remote machine. Pc-Anywhere would really be overkill and would add a lot of overhead on the system.
    Maybe someone else has some sugestions?
    PassMark
      • 11114
      Some other 3rd party software solutions have been suggested.
      RAdmim http://www.famatech.com/
      Windows Remote desktop
      RealVNC http://www.realvnc.com
      EXPERTVNC http://www.expertvnc.com/index1.html
      Remote Helpdesk http://www.gidsoftware.com/remotehelpdesk.htm
      We haven't experimented with any of these, so we can really say which ones work and which don't .
      PassMark
