burnintest installation problem
  • eran
    Hi support –
    I bought the USB Loopback plug and I purchased the Burn in test but I can't install the bit S/W properly,
    I downloaded the S/W but and I installed it I also installed Directx 8 and the windows is Win2000.
    But when I double click on the icon of the BIT it doesn’t run.
    I’ve purchased it and I have the “keycode/serial number” , I’ve also entered it into the “key.dat”. but the S/W doesn’t work at all.
    Please advice.
  • Ian (Support)
    • 286
    BurnInTest failing on startup
    PC's with Intel Motherboards and old versions of the SensorDLL.dll (Intel
    temperature sensor library) fail to load and lead to BurnInTest to fail on startup. You should install Intel Active Monitor Plus to correct this (there may be a patch required before installation - see Intel's site). A new version of BurnInTest is also available from to correct this:
    http://www.passmark.com/ftp/bitpro.exe
    Ian
