question about burnintest's 3d test
  • ken007
    • Sep 2007
    hmm..guys i am testing my 3d test ,when you are testing the 3d it will appear a plane flying around right?well i notice every second the video image stop a while,like stuttering,is this normal?btw it says my 3d card doesnt have error
    the 3d card i testing is 8800gts
    It can be normal is you have other tests running using the CPU or doing disk transfers.
    • ken007
      • Sep 2007
      but i just run the 3d testO.O...
        If you have nothing else running on your PC and you have set the duty cycle to be 100% in BurnInTest. Then the 3D test should be fairly smooth.
        • ken007
          • Sep 2007
          thanks man!!i thought i got a defective card lol
