Net work test
  • zhaao
    • Sep 2007
    Net work test
    Issue description:Setting Network as 100%,any other items load default,starting testing,then Network1 will display"Timeout waiting for packet". And then I found this error will disappear when using E6700/2.66GHz/1066 CPU or change 965 CPU ratio to x12 from x14.
    My questions:
    1. Why does have this issue?
    2. What's the principium of Network test? And how to do this test item?
    Testing config:
    MB:Intel P31A + ICH7;
    CPU:Pentium®Extreme/965/3.73GHZ/4M/1066/05B;
    HDD:Seagate/160GB/ST3160815AS;
    Memory:UMAX/667-512MB X2;
    VGA:COLORFUL七彩虹/M/N 天行7300GT CF 白金版 128M F33;
    Power:Antec/True550;
    OS:Windows XP+SP2 (ENG);
    Burn in:Burn in 5.3 build 1011 rev 2;
    Lan chip:Broadcom 5786.
    The CPU type and bus speed multiplier should have no effect on the network test. The real cause of the difference in behaviour is probably elsewhere.
    For details of the configuration options and a description of how the network test works see the BurnInTest users guide.
