Announcement
No announcement yet.
EMC test: Scrolling "H"
  • Filter
  • EMC test: Scrolling "H"
    Hello people!
    Having right now updated to Version 4.0 we want to use BurnIn Pro for several EMC tests. For this we have set each duty cycle to 100%.
    The Problem is that - when tests are started - the active window always is "3D Test" preventing the scrolling "H" from scrolling.
    We always need to click beside this window to make the scrolling "H" the active window.
    Having used version 3.0 before automatically the scrolling "H" were in the front and each BurnIn window was running inactive in the background.
    Is there a way to solve this problem (perhaps just a simple option, we haven't found yet)?
    Thanks for your quick help,
    Chris
  • #2
    Monitor EMC test - Scrolling H's
    Chris,
    The simple way to have the scrolling 'H' test start when you select start, is to turn off the 3D test (in "Test configuration and duty cycles") before running the EMC test pattern.
    Best Regards,
    Ian
    PassMark Software
    Update: In addition to the scrolling H test, we have have the Test pattern with moving element image generator
    • #3
      Re: Monitor EMC test - Scrolling H's
      The simple way? Does it mean that there is another solution for this problem?
      Chris
      [quote="ian - passmark"]Chris,
      quote]
