Burnintest to load on usb or burn on CD
  • simba
    • Apr 2008
    I have downloaded the burnintest without the installer and uninstaller. It is a zip folder. Now how do I proceed to burn on CD or save it in USB stick. Do I need to Extract the files before saving on USB or burning CD or do I just burn as it is ie zip format?
    Also, how do I create the key.dat file? The instructions are not that clear. do I need to create this after I have saved it on USB or burnt the CD? Also, I can't find the bit.exe directory.
    I would appreciate clearer instructions so that I may complete this task successfully and then test my pc from USB or CD.
    Thanks!
    Simba
    We have updated the instructions located on our FAQ page, http://www.passmark.com/support/bit_faq.htm, with the topic:
    Q. How can I setup BurnInTest to run from a USB drive or CD/DVD under Windows ?
    Ian
