USB Drive testing failures - Data Verify failure
  • Comark Corp
    • Feb 2006
    • 98
    I am trying to do testing on 2.5" hard drives connected through a USB to PATA adapter (USB 2.0). I am running only the drive test at a 100% duty cycle. For some reason, I'm getting "data verify failure" on average about once few minutes. So, I created a .cmd script that copies and verifies the same data file that BurnInTest generates in a continuous loop and get no errors after hours of testing. I've tried three different adapters from different manufacturers, as well as a number of different hard drives. Using 5.3 build 1014.
    The test script I made looks like this:
    :start
    xcopy /v /y bittestE00001.bin e:
    fc/b crash.bin e:\crash.bin
    if errorlevel 1 goto error
    goto start
    :error
    ECHO an error occurred!
    Any thoughts?
    Thanks.
    Jay W.
    Diagnostic Engineer
    Comark Corporation
    93 West St.
    Medfield, MA 02052
    http://www.comarkcorp.com
    It might be interesting if you posted the log from BurnInTest showing the exact errors.
    Your script would only seem to test a small part of the surface of the disk. BurnInTest will test the entire disk if you leave it to run. So I don't think you are comparing apples to apples.
    Also, I think your script copies a file called bittestE00001.bin, but verifies a file called crash.bin, which is not the same file as you copied.
    • Comark Corp
      • Feb 2006
      • 98
      Sorry about the filenames, I renamed the bittest file to crash.bin, but when I posted my question I renamed it back so as not to cause confusion. I guess that backfired, eh?
      In actuality the file being copied and compared is crash.bin which is a renamed bittest file. And, as you say, I'm not testing the entire drive.
      Here's the log. Thanks again.
      PassMark BurnInTest Log file - http://www.passmark.com
      BurnInTest V5.3 Pro 1014
      Logging detail level: Normal
      SYSTEM INFORMATION
      Computer Name: [deleted]
      Date: 04/23/08 08:46:23
      Operating system: Windows 2000 Professional Service Pack 4 build 2195
      Number of CPUs: 1 (2 Core(s)/CPU, 1 Logical(s)/Core)
      CPU type: Intel(R) Pentium(R) D CPU 3.00GHz
      CPU features: MMX SSE SSE2 SSE3 DEP PAE
      CPU1 speed: 3297.1 MHz
      CPU L2 Cache: 2 MB (L3 Cache: 0 KB)
      RAM: 2038 MB
      Video card: Intel(R) 82945G Express Chipset Family (Resolution: 1152x864x32)
      Disk drive: Model ST3120026AS (Size: 111.8GB)
      Disk drive: Model TOSHIBA MK4025GAS USB Device (Size: 37.3GB)
      Optical drive: HL-DT-ST RW/DVD GCC-4480B
      DETAILED EVENT LOG
      LOG NOTE: 2008-04-23 08:46:23, Status, PassMark BurnInTest V5.3 Pro 1014
      LOG NOTE: 2008-04-23 08:46:24, Status, Main Tests started
      SERIOUS : 2008-04-23 08:53:05, Disk, E: Data Verify failure
      LOG NOTE: 2008-04-23 08:53:05, Disk, File: E:\BurnInTest test files\~bittestE00010, Value Read: 16, Value Expected: 17, Offset 126010120, Ops: 7717715968
      LOG NOTE: 2008-04-23 08:53:05, Disk , Disk Error (E: Data Verify failure in Cycle 9 with pattern Sequential data pattern
      SERIOUS : 2008-04-23 08:54:35, Disk, E: Data Verify failure
      LOG NOTE: 2008-04-23 08:54:35, Disk, File: E:\BurnInTest test files\~bittestE00012, Value Read: 140, Value Expected: 172, Offset 399264673, Ops: 9317548032
      LOG NOTE: 2008-04-23 08:54:35, Disk , Disk Error (E: Data Verify failure in Cycle 11 with pattern Sequential data pattern
      SERIOUS : 2008-04-23 08:55:08, Disk, E: Data Verify failure
      LOG NOTE: 2008-04-23 08:55:08, Disk, File: E:\BurnInTest test files\~bittestE00013, Value Read: 0, Value Expected: 150, Offset 24887178, Ops: 9745563648
      LOG NOTE: 2008-04-23 08:55:08, Disk , Disk Error (E: Data Verify failure in Cycle 12 with pattern Sequential data pattern
      SERIOUS : 2008-04-23 08:55:44, Disk, E: Data Verify failure
      LOG NOTE: 2008-04-23 08:55:44, Disk, File: E:\BurnInTest test files\~bittestE00014, Value Read: 0, Value Expected: 43, Offset 103300382, Ops: 10243899392
      LOG NOTE: 2008-04-23 08:55:44, Disk , Disk Error (E: Data Verify failure in Cycle 13 with pattern Sequential data pattern
      SERIOUS : 2008-04-23 08:57:49, Disk, E: Data Verify failure
      LOG NOTE: 2008-04-23 08:57:49, Disk, File: E:\BurnInTest test files\~bittestE00017, Value Read: 2, Value Expected: 26, Offset 243943690, Ops: 12486901760
      LOG NOTE: 2008-04-23 08:57:49, Disk , Disk Error (E: Data Verify failure in Cycle 16 with pattern Sequential data pattern
      SERIOUS : 2008-04-23 08:58:22, Disk, E: Data Verify failure
      LOG NOTE: 2008-04-23 08:58:22, Disk, File: E:\BurnInTest test files\~bittestE00018, Value Read: 0, Value Expected: 59, Offset 25971498, Ops: 12916162560
      LOG NOTE: 2008-04-23 08:58:22, Disk , Disk Error (E: Data Verify failure in Cycle 17 with pattern Sequential data pattern
      SERIOUS : 2008-04-23 08:59:03, Disk, E: Data Verify failure
      LOG NOTE: 2008-04-23 08:59:03, Disk, File: E:\BurnInTest test files\~bittestE00019, Value Read: 0, Value Expected: 144, Offset 200883070, Ops: 13523419136
      LOG NOTE: 2008-04-23 08:59:03, Disk , Disk Error (E: Data Verify failure in Cycle 18 with pattern Sequential data pattern
      SERIOUS : 2008-04-23 08:59:38, Disk, E: Data Verify failure
      LOG NOTE: 2008-04-23 08:59:38, Disk, File: E:\BurnInTest test files\~bittestE00020, Value Read: 37, Value Expected: 39, Offset 72895508, Ops: 13993508864
      LOG NOTE: 2008-04-23 08:59:38, Disk , Disk Error (E: Data Verify failure in Cycle 19 with pattern Sequential data pattern
      SERIOUS : 2008-04-23 09:00:14, Disk, E: Data Verify failure
      LOG NOTE: 2008-04-23 09:00:14, Disk, File: E:\BurnInTest test files\~bittestE00021, Value Read: 128, Value Expected: 176, Offset 104745628, Ops: 14499971072
      LOG NOTE: 2008-04-23 09:00:14, Disk , Disk Error (E: Data Verify failure in Cycle 20 with pattern Sequential data pattern
      LOG NOTE: 2008-04-23 09:01:29, Status, Test run stopped
      RESULT SUMMARY
      Test Start time: Wed Apr 23 08:46:23 2008
      Test Stop time: Wed Apr 23 09:01:27 2008
      Test Duration: 000h 15m 04s
      Disk (E: New Volume) 22 15.686 Billion FAIL 9 Data Verify failure
      TEST RUN FAILED
      SERIOUS ERROR SUMMARY FOR THE LAST TEST RUN
      SERIOUS : 2008-04-23 08:53:05, Disk, SERIOUS: Data Verify failure (x 9)
      Jay W.
      Diagnostic Engineer
      Comark Corporation
      93 West St.
      Medfield, MA 02052
      • Comark Corp
        • Feb 2006
        • 98
        FWIW, I just tried a 1 hour test with your USB 2.0 loopback devices.
        There were no failures.
        Jay W.
        Diagnostic Engineer
        Comark Corporation
        93 West St.
        Medfield, MA 02052
        • Comark Corp
          • Feb 2006
          • 98
          Thought I'd follow up with my findings. It turns out that a particular USB to PATA chip is responsible. This chips were located in a number of these devices we had lying around, including ones from Rosewill and Kingwin. The vendor ID of the internal chip is 152D which according to http://www.linux-usb.org/usb.ids is
          152d JMicron Technology Corp. / JMicron USA Technology Corp.
          2338 JM20337 Hi-Speed USB to SATA & PATA Combo Bridge
          The Rosewill RCW-618 device can be seen here:
          http://www.newegg.com/Product/Product.aspx?Item=N82E16812119244
          We managed to find a device with another chipset inside and
          the problem does not occur.
          kudos to Passmark - I guess the data patterns you use are
          quite effective!
          Thanks for your help.
          Jay W.
          Diagnostic Engineer
          Comark Corporation
          93 West St.
          Medfield, MA 02052
            Thanks for posting the solution.
            It is kind of scary however that such serious and easily detected faults are in all these USB drive adapters. There must be a lot of people out their getting some low level data corruption without knowing why.
            If you have an account with Newegg maybe you should post your findings to Newegg as a review to avoid grief for others.
