PC, slow after test
  • Bogge72
    • May 2008
    PC, slow after test
    I just tested this burnin test and passed it. I did a default test.
    So far so good.
    But.. now, after the test everything I do goes really really slow.
    It take ages to change homepages, start up games and so on.
    Feels Im back with a x486 with 2MB Ram.
    Have anyone a clue or have the same experience?
    It normal to have a short period (1 - 2 minutes) of poor performance after running any program that uses a lot of RAM. The operating systems will often have to swap a lot of data to and from the the disk, slowing down the machine.
    But it should return to normal very quickly. Did you check the CPU usage? Maybe there was some other program running in the background? Did you try a reboot?
