Announcement
No announcement yet.
Fonts for BIT
  • Filter
  • Fonts for BIT
    Hello Passmark,
    I used XPe like a test image to run BIT test.
    BIT interface looks fine but BIT references page looks abnormal.
    Can you tell me what fonts should I add for BIT?
    Thanks,
    Thanh
  • #2
    Windows XP embedded
    You need the MS Sans Serif( font installed. We have had a report where this seemed to be installed, but the actual font file was missing. So, if this font appears to be installed then delete it and re-install it.
    Ian
    • #3
      Thanks,
      Thanh
