Hi Passmark,
I have some system has more than 10 NICs.
I use 2003 R2 as a based OS and BIT 5.3 Pro standalone version 1014.
BIT only recognizes 8 NICs in standard test.
In NIC advanced test with an end point service running in a server, if I set 10 or even 4 NICs to test, it won't work but exit without any message.
I can set BIT test the first 8 NICs then automatically start BIT test on the remaining NICs. However, we do not know exactly which NICs have been tested and untested to set.
Do you have any suggestion on this issues?
Thanks,
Thanh
www.ncst.com
Thanks,
Thanh
www.ncst.com
