Garbage issue when run 3D Test
  • GI Wan
    • Dec 2006
    • 30
    Hi ,
    We had found the garbage issue at 3D Test , actually we don't found any errors in the test result from Burn In test, but the 3D test screen will have garbage issue then the NB LCD garbage then system hang up .
    We had take the failure unit to run the 3DMark2006 & play 3D games , no any failure appear , do you have any idea or suggestion of this issue ??
    1.The software version : Burnin5.3 Build 1034
    2. The operating system version : Windows Vista Ultimate SP1 RTM 32bit.
    It might have been good if you had described in more detail exact what this "garbage" looks like. Or taken a photo.
    I am not sure what you mean by this.
    I would try,
    1) Updating the video card device drivers
    2) Running the 3D test by itself, in case one of the other test is effecting the 3D behavior.
    3) Try replacing the video card as an experiment.
