BurnInTest crash issue
  • Czolth
    • Nov 2008
    Dear teams,
    When I loaded and run this program with v5.3 on HD or USB for 1.5hrs and then closed the utility, the system would often crash the same time.
    How can I fix this issue?
    Thanks in advance for your help.
    Best Wishes,
    Czolth
    If the entire PC crashes, then it is most likely a device driver or hardware issue. Is there a error message of some sort, e.g. a blue screen?
