No help info on burning test pro
  • joville
    • Nov 2004
    I purchased the burning test pro, as well as a serial loopback plug and a parallel loop back plug.
    I also received the test CD and DVD set that i ordered.
    My question is: How do you use these two disks? there was no instruction manual or help file on either disk, the only info I found was that you have to use the disk with the burning test pro software, but how do you use the two disks in conjunction with with the burning test pro software, I can find no infomation regarding this.
    Also while at it, no info on how to use the loop back plugs either.
    John
    • 11114
    You can find some details on our web site,
    http://www.passmark.com/products/testcddvd.htm
    http://www.passmark.com/products/loopback.htm
    and more details in the BurnInTest users guide, on this page,
    In particular, the sections of the user guide titled, CD/DVD testing , serial & parallel port testing will be useful to you.
    PassMark
