Sample which occurred error message re-test will PASS with cancel the memory test ite
Sample which occurred error message re-test will PASS with cancel the memory test item
Test sample:20 sets ,
error message:10 sets(xp system pass)(vista 32 8 sets)(vista 64 x 2sets)
Brand : 3 (HP , ASUS ,..etc)
1.What you see for the memory test looks normal.
Normal: 1. momory test use more less capacity (under 0.2G x 4 )
2. release smoothly the RAM capacity
Abnormal: 1.momory test use more much capacity (over 0.7G x 4 )
2. release difficulty the RAM capacity
2.It does look like BurnInTest is using something that is not releasing
memory and hence the system runs out of memory.
How to know something which runs out of memory? thanks
