Hard Drive Failure Detected
  • johnlk
    • Mar 2009
    I have used burnintest to test my newly built system. Unfortunatly The tests show that one of my partitions has a hardware failure. I have 2 partitions, the one which has windows installed on is showing the failure. I changed the hard drive for a new one and again im having the same problem. When i run just the hard drive test alone it passes. Also i used the manufacturers hard drive utility to test the hard drive and it passes...
    Is it possible im gettin the failure due to a partition? from a 500 GB hard drive with 2 partitions 50 gb and 450 gb, the 50 gb fails. Can you please advise me as this is driving me nuts! Thanks in advanced..
    What version of BurnIntest are you using and what was the error that you are seeing?
