BIT 5.3 Pro suddenly shuts down
  • raw enha
    • Mar 2009
    i am running 5.3 Pro on Windows XP Pro 32 bit with SP/3. If I run BIT for 1 minute...everything is fine. 4 hours....everything is fine.
    On three occassions i have tried to run it for 8 hours; in all cases the application suddently shuts down. the windows logs via EVENTVWR are all clean, system and application log have no errors, not even benign ones, just run of the mill windows is working stuff. below is the BIT log looks like, notice how it just stops (the sudden exit seems to occur somewhere between 6 hours and the end of the test). After that, i show an example of when it works fine (4 hour run).
    No other applications or processes are suffering. in fact, the computer has been on and rock solid for about a week except for 1 restart just in case with testing BIT.
    Basically, BIT works fine, but not for 8 hours. Also, watching it, all systems do run at least 1 complete cycle without errors (the harddrive is the only system that gets just 1 complete pass in, all the others have many passes and no fails).
    BurnInTest V5.3 Pro 1014
    Logging detail level: Normal
    SYSTEM INFORMATION
    Computer Name: workstation1
    Date: 03/27/09 13:15:33
    Operating system: Windows XP Professional Service Pack 3 build 2600
    Number of CPUs: 1 (2 Core(s)/CPU, 1 Logical(s)/Core)
    CPU manufacturer: AuthenticAMD
    CPU type: AMD Athlon(tm) 64 X2 Dual Core Processor 5000+
    CPU features: MMX 3DNow! SSE SSE2 SSE3 DEP PAE
    CPU1 speed: 2600.1 MHz
    CPU L2 Cache: 512 KB
    RAM: 1535 MB
    Video card: ATI Radeon HD 3400 Series (Resolution: 1600x1200x32)
    Disk drive: Model NVIDIA MIRROR 298.08G (Size: 298.1GB)
    Optical drive: PIONEER DVD-RW DVR-109
    DETAILED EVENT LOG
    LOG NOTE: 2009-03-27 13:15:33, Status, PassMark BurnInTest V5.3 Pro 1014
    LOG NOTE: 2009-03-27 13:15:39, Status, Main Tests started
    __________________________________________________ _____
    and here is the summary for a 4 hour run which does complete:
    RESULT SUMMARY
    Test Start time: Mon Mar 30 08:28:08 2009
    Test Stop time: Mon Mar 30 12:28:13 2009
    Test Duration: 004h 00m 05s
    CPU - Maths 4690 673 Billion PASS 0 No errors
    CPU - SIMD 1146 870 Billion PASS 0 No errors
    Memory (RAM) 32 55.167 Billion PASS 0 No errors
    2D Graphics 131 131463 PASS 0 No errors
    Disk (C: ) 1 10.734 Billion PASS 0 No errors
    Sound 273 235 Million PASS 0 No errors
    TEST RUN PASSED
    SERIOUS ERROR SUMMARY FOR THE LAST TEST RUN
    There was a similar sounding problem with XP SP3 that was resolved in V5.3.1034. Please down the latest build of V5.3 from the bottom of this page, or upgrade to V6:
    http://passmark.com/download/bit_download.htm
    Ian
