WINPE issue
  • Reaper
    • Jul 2009
    WINPE issue
    Ok Not sure what I am doing wrong I have followed the white paper that you posted for creating a WINPE cd with BIT on it. Yet when I boot to the CD there is no BurnInTest in the program files on the cd....
    I am using the AIK 2.0 on a XP machine with SP3 and using the msvfw32.dll file from windows\system32\ folder
    Any thoughts?
    Joe
    I guess that maybe you didn't do the final step of copying the image to the correct directory (I did this a few times when preparing the document).
    This step is:
    9. Make the boot disk.
    Now at this point you can rename the c:\bitpe\winpe.wim to boot.wim and place it in the ISO\Sources folder to burn a CD or you can add it to the Boot Images in Windows Deployment Services.
    Ian
    • Reaper
      • Jul 2009
      that was it....I guess I need to learn how to read the instructions...LOL
      Thanks Again for your help!
