BurnInTest causes system reboot
  • Jacky.Tsai
    • Aug 2009
    Hi Passmark,
    Atom platform with CPU throttling in 40 degree environment causes the system to reboot in MS XPP OS and the messenge of OS is "System had recovered from serious error". When the throttling feature of CPU is disabled then systme is stable when runs the burn in test at the same environment.
    Jacky
    You have a hardware fault, device driver fault or design flaw in the system. If there is not more details in the error, you'll need to do more testing and go though a process of elimination to determine the true cause of the problem.
