Announcement
No announcement yet.
BITPro 6.0 + WinPE 3.0 works fine, and question
  • Filter
  • BITPro 6.0 + WinPE 3.0 works fine, and question
    Just wanted to confirm that Burn In Test 6.0 and WinPE 3.0 works fine for a NO OS environment; I have all the supported tests working right now.
    I have a question though; since all versions of WinPE automatically reboot after 24 hours, we have a problem doing Burn In testing over a weekend (when no one is here for 48 hours). Is there any way to have BITPro automatically save the results as all three possible save files as it reboots on it's own? (Certificate, results, and log files?)
    I see that you can tell it to save as one type, but we actually need all three...
    Thanks!
    -S
  • #2
    In the current version there is no way to save all 3 file formats automatically (just one). We will add this as a candidate feature for a scripted test (i.e. generate log file result commands). This would be a candidate for the next major release (no time frame available).
    Thanks.
    Ian
    • #3
      Win PE 3.0 should be rebooting after 72 hours, not 24.
      • #4
        Yes, you are right. According to the documentation I have:
        24 hours - Microsoft® Windows® PE, Version 2005
        72 hours - Microsoft® Windows® PE, Version 2.0, 2.1 and 3.0
        Ian
