We are experiencing a strange issue where if we disconnect the monitor (we have a large rack for Burn In Testing, and just a few monitors) we get the error "The 3D Test was interrupted".
This has happened with build 6.1014 under all OSes (XP. Vista, 7, 64-bit or 32-bit). It's happened with multiple video cards, all running the latest WHQL drivers (Nvidia/ATI).
I also have unconfirmed reports this is also happening when running the 2D test ("The 2D Test was interrupted").
We typically either run 3D or 2D, depending on the video card.
We can easily reproduce this on a machine that exhibits the error simply by disconnecting/reconnecting the monitor while testing.
Is this a known issue, and if so, is there a workaround?
Thanks,
S
Thanks,
S
