Run BurnInTest from USB drive
  • ahrens
    • Dec 2009
    I have got a problem with starting BurnInTest V6.0 Pro from USB drive.
    I installed BurnInTest normally on my PC, started it and chose File -> Install BurnInTest to USB drive, followed the installation and entered the license key.
    Then I wanted to start BurnInTest from the USB drive and 2 Errors appeared:
    1. "A key.dat file exists in the application directory, but it does not contain a valid username and/or key."
    I am sure, that the license key is correct, because I used it before for the installation on the PC.
    2. Is the errormessage: "Startup Error Number: 1"
    after that the program is closed.
    If you selected File->Install BurnInTest to USB drive, then selected an installation type of licensed and entered your valid username and key, then the key.dat file on your USB drive should not be empty, but contain your Username and key. Could you retry, if you still have the problem, please let me know.
    Ian
