We are seeing the following error running Burn In Test. Here is a log of the run...any ideas? I assume since it is "Maths" it has something to do with CPU, but could you point us in the right direction? I am told we have already changed CPUs, motherboard, and memory so far...
CPU/RAM @ 90%
HDD @ 100%
Network @ 90%
Not worried about the single network error obviously.
Thanks,
S
PassMark BurnInTest Log file - http://www.passmark.com
Date: 12/21/09 09:19:34
BurnInTest V6.0 Pro 1017
(64-bit)Technician: xxx
Logging detail level: Normal
SYSTEM SUMMARY
Windows 7 Ultimate Edition build 7600 (64-bit),
2 x Intel(R) Xeon(R) CPU E5530 @ 2.40GHz,
48.0GB RAM,
3724GB HDD,
CD/DVDRW,
GENERAL
System Name: MININT-241F761
Motherboard Manufacturer: Supermicro
Motherboard Name: X8DTN
Motherboard Version: 1.1
BIOS Manufacturer: American Megatrends Inc.
BIOS Version: 080015
BIOS Release Date: 10/07/2009
Serial number: xxxxxx
CPU
CPU Type: Intel(R) Xeon(R) CPU E5530 @ 2.40GHz
Codename: Gainestown
CPUID: CPU1: Family 6, Model 1A, Stepping 5, Revision D0
CPUID: CPU2: Family 6, Model 1A, Stepping 5, Revision D0
Socket: LGA1366
Lithography: 45nm
Physical CPU's: 2
Cores per CPU: 4
Hyperthreading: Enabled
CPU features: MMX SSE SSE2 SSE3 SSSE3 SSE4.1 SSE4.2 DEP PAE Intel64 VMX
Clock frequencies:
Measured CPU speed: 2401.3 MHz
Multiplier: x18.0
Base Clock: 133.3 MHz
Muliplier range: Min: x12, Max non turbo: x18
Cache per CPU package:
L1 Instruction Cache: 4 x 32 KB
L1 Data Cache: 4 x 32 KB
L2 Cache: 4 x 256 KB
L3 Cache: 8 MB
TDP Limit: 80 Watts
TDC Limit: 70 Amps
MEMORY
Total Physical Memory: 49143MB
Available Physical Memory: 46781MB
Memory devices:
0:
- 4096MB, 1024MHz,
1:
- 4096MB, 1066MHz,
2:
- Not populated
3:
- 4096MB, 1066MHz,
4:
- 4096MB, 1066MHz,
5:
- Not populated
6:
- 4096MB, 1066MHz,
7:
- 4096MB, 1066MHz,
8:
- Not populated
9:
- 4096MB, 1066MHz,
10:
- 4096MB, 1066MHz,
- Serial number: ÿÿÿ
11:
- Not populated
12:
- 4096MB, 1066MHz,
13:
- 4096MB, 1066MHz,
14:
- Not populated
15:
- 4096MB, 1066MHz,
16:
- DDR3, 4096MB, 1066MHz,
17:
- Not populated
DISK VOLUMES
C: Local drive, NTFS, (3724.00GB total, 3723.80GB free)
D: Optical drive, DVD-ROM UJDA780
X: Local drive, Boot, NTFS, (0.03GB total, 0.03GB free)
DISK DRIVES
Fixed disk (Size: 3724.00GB)
OPTICAL DRIVES
D: MATSHITA DVD-ROM UJDA780 (CD/DVDRW)
NETWORK
Intel(R) 82576 Gigabit Dual Port Network Connection
PORTS
RESULT SUMMARY
Test Start time: Fri Dec 18 11:24:17 2009
Test Stop time: Mon Dec 21 08:55:50 2009
Test Duration: 069h 31m 33s
Temperature CPU 1 average (Min/Current/Max): 36.5C / 48.3C / 51.8C
Temperature CPU 1 core 1 (Min/Current/Max): 39.0C / 52.0C / 54.0C
Temperature CPU 1 core 2 (Min/Current/Max): 33.0C / 47.0C / 50.0C
Temperature CPU 1 core 3 (Min/Current/Max): 39.0C / 48.0C / 53.0C
Temperature CPU 1 core 4 (Min/Current/Max): 35.0C / 46.0C / 50.0C
Temperature CPU 2 average (Min/Current/Max): NA / NA / NA
Temperature CPU 2 core 1 (Min/Current/Max): NA / NA / NA
Temperature CPU 2 core 2 (Min/Current/Max): NA / NA / NA
Temperature CPU 2 core 3 (Min/Current/Max): NA / NA / NA
Temperature CPU 2 core 4 (Min/Current/Max): NA / NA / NA
CPU 59131 817 Trillion FAIL 3272 System unable to allocate memory resource
Memory (RAM) 482 47.028 Trillion PASS 0 No errors
Network 1 8607 68.863 Million FAIL 1 Timeout waiting for packet
Disk (C
26 2.103 Trillion PASS 0 No errors
TEST RUN FAILED
DETAILED EVENT LOG
SERIOUS: 2009-12-18 11:38:03, Maths, System unable to allocate memory resource
(cut for brevity)
SERIOUS: 2009-12-18 11:41:01, Maths, System unable to allocate memory resource
LOG NOTE: 2009-12-19 10:27:23, Network 1, User set Network timeout exceeded.
SERIOUS: 2009-12-19 10:27:24, Network, Timeout waiting for packet
LOG NOTE: 2009-12-21 08:55:50, Status, Test run stopped
CPU/RAM @ 90%
HDD @ 100%
Network @ 90%
Thanks,
S
SYSTEM SUMMARY
48.0GB RAM,
3724GB HDD,
CD/DVDRW,
GENERAL
CPU
Socket: LGA1366
Lithography: 45nm
Physical CPU's: 2
Cores per CPU: 4
Clock frequencies:
Multiplier: x18.0
L3 Cache: 8 MB
TDP Limit: 80 Watts
TDC Limit: 70 Amps
MEMORY
Memory devices:
0:
- 4096MB, 1024MHz,
1:
- 4096MB, 1066MHz,
2:
- Not populated
3:
- 4096MB, 1066MHz,
4:
- 4096MB, 1066MHz,
5:
- Not populated
6:
- 4096MB, 1066MHz,
7:
- 4096MB, 1066MHz,
8:
- Not populated
9:
- 4096MB, 1066MHz,
10:
- 4096MB, 1066MHz,
11:
- Not populated
12:
- 4096MB, 1066MHz,
13:
- 4096MB, 1066MHz,
14:
- Not populated
15:
- 4096MB, 1066MHz,
16:
17:
- Not populated
DISK VOLUMES
DISK DRIVES
OPTICAL DRIVES
NETWORK
PORTS
RESULT SUMMARY
Disk (C
26 2.103 Trillion PASS 0 No errorsTEST RUN FAILED
DETAILED EVENT LOG
(cut for brevity)
