command line for auto installation
  • rotcivlamora
    • Jan 2010
    Can i have the command line for auto installation of Burnintest 6.0 windows version
  • Ray (PassMark)
    PassMark Engineer
    • Nov 2003
    • 32
    The following are command-line parameters for silent installation (to be used with the installer executable):
    /SP-
    This will suppress the startup prompt (with the text "This will install... do you wish to continue?")
    /SILENT
    This will suppress the wizard and background window but the installation progress will still appear. Error messages and startup prompt will still appear unless /SP- is also specified.
    /VERYSILENT
    This is the same as /silent but will also hide the progress window.
    /SUPPRESSMSGBOXES
    This will suppress the prompts such as "Keep newer file?" and "File exists, confirm overwrite". It will automatically select the default choice for these prompts.
    Ray
    PassMark Software
    • JDowning
      • Aug 2011
      Any More Command Line Options available
      The command line parameteres provided were great!!! THANX Ray!!!
      Now I am curious if there is a way to "uncheck" the launch application checkbox during the unattended install?
      I am hoping to automate the installation of the BurnIn and Performance Test software at once.
      Thanx
        • 11112
        Innosetup is used as the installer.
        Supported command line parameters are here,
        http://unattended.sourceforge.net/InnoSetup_Switches_ExitCodes.html
        I didn't see one for the checkbox however.
        • JDowning
          • Aug 2011
          Do you suppose the "/TASKS" parameter could be used? Do you, or anyone, know what the "Launch Performance Test" Task/Checkbox would be named?
            • 11112
            I don't think /TASKS can be used for what you want.
