Optical Drive Test
  • robt
    • Feb 2010
    Optical Drive Test
    I need to find a more real world simulation of the optical drive. I use the CD data read test at a 5% duty cycle. However, even at this low duty cycle the drive motor does not have time to spin down between tests. Is there a way to adjust the time between tests other than duty cycle?
    Look at the scripting options in BurnInTest.
    Or you could create a DOS script that for example called BurnInTest for a 1 min test every 1 hour.
