I have a problem with BIT 5.1. After the test I have to call a batch file to execute following tests, but I have to use a relative path to start test.cmd which is located in the same Dir then BIT.
For testing purposes I start BIT from the command line in it's application directory: "bit.exe -p -c .\stress.bitcfg -r".
The tests starts, but after completing tests a message box appears that says: "Error running external file...".
What's wrong?
What's wrong?
