Serial Port test failed with BurnIn test tool under SLES11 64bit.
  • kenb
    • Mar 2010
    The serial burning test runs flawlessly on all other Linux's including the 32-bit version of SLES 11. But with 64-bit SLES 11, it always accumulates sme failures for every 1000 or so cycles.
    Anyone else see this problem? If so, is it a problem with the BurnIn serial test or with 64-bit SLES 11?
    If it's only restricted to one particular build of Linux it's more lilely to be a difference in configuration or linux bug rather than a bug in BurnInTest.
    • kenb
      • Mar 2010
      Same problem occurs under RHEL6 64-bit
      I can't believe no one else is asking about this issue.
        What are the exact error message(s)?
        What hardware is in use?
        What version of BurnInTest are you using?
        What other tests are running at the same time?
        What type of loopback plug are you using?
