Stress test for CPU
  • Kary1001
    Stress test for CPU
    How can I do a stress test (CPU) using burnintest Pro 6 and how long should I do it for?
    • 11115
    If you are only interested in testing the CPU (and not the RAM, hard disk, etc..), then turn off all tests except the CPU test. Set the duty cycle to 100% for the CPU test. Then run the test for a couple of hours.
    If the test runs for a couple of hours without fault, then it is highly likely the CPU is good.
    • centropypc
      Sweet will run for two hours and see how it goes.
