Bitpro 6 64-bit @erver 2008 crashes.
  • chslab-mjh
    • Sep 2010
    I am running BurnInTest 6.0 64-bit on a Dell R610 with Windows Server 2008 64-Bit.
    The Bitpro GUI always launches successfully, but sometimes when I click the start button Bitpro crashes.
    Here is the output from the error message that is displayed:
    Problem signature:
    Problem Event Name: BEX64
    Application Name: bit.exe
    Application Version: 6.0.1021.6
    Application Timestamp: 4bfca61e
    Fault Module Name: bit.exe
    Fault Module Version: 6.0.1021.6
    Fault Module Timestamp: 4bfca61e
    Exception Offset: 000000000020f070
    Exception Code: c0000417
    Exception Data: 0000000000000000
    OS Version: 6.0.6001.2.1.0.274.10
    Locale ID: 1033
    Additional Information 1: 4ed0
    Additional Information 2: b45058f68f03747aaea6a3e7ab68ff26
    Additional Information 3: 5a31
    Additional Information 4: 1011b852b743b6d7813b46e2b0d384ec
    Read our privacy statement:
    http://go.microsoft.com/fwlink/?linkid=50163&clcid=0x0409
    Any assistance you can provide in fixing this issue will be greatly appreciated.
    You are a couple of patch releases behind the current release.
    Can you get the current software. If you still have a problem, can you turn on level 2 logging and E-mail us the log.
    Also you might try running just one test at a time to isolate which test module provokes the crash. If it comes down to the 3D test, then make sure you have up to date video card drivers.
