Announcement
No announcement yet.
WinPE and BartPE Errors
  • Filter
  • WinPE and BartPE Errors
    I am currently using the trial version of BurnInTest to evaluate if I would like to purchase the software. I am having errors with both the WinPE and BartPE environments. I am using Windows XP SP3, but used the Vista msvfw32.dll when creating the WinPE disc.
    1) When attempting to run BurnInTest in WinPE, I receive an error that states something similar to "Error during startup. A problem has happened during your installation. Please uninstall the software and reinstall it. Error Code: 1"
    2) When creating the BartPE bootdisc, the BurnInTest plug-in gives 2 errors and will not allow the disc to be burned. It states that it is missing both "Endpoint.exe" and "FTD2XX.DLL"
    Any suggestions on how to solve these errors?
  • #2
    1. If you send us an email we can send you a trial license key. This is probably the easiest way to resolve this problem.
    2. Both of these files are included in the current BurnInTest Professional distribution, so I assume you are using BurnInTest Standard. If this is the case, you should remove the following 2 lines from the BurnInTest BartPE plugin installation file, bit.inf:
    Endpoint.exe=a,,1
    FTD2XX.DLL=a,,1
