3D and video playback run abnormally on switchable graphics with BurnIn test pro 6
  • Andy.Chang
    • Dec 2010
    Hi Sir, did you every run burnIn test pro 6 on switchable graphics?
    When we perfom 3D/2D/Video playback test together, 3D test no operation(The test window has white screen), video playback window black screen (no more operation after 30 counts operation), but 2D test run normally.
    This issue only occur on switchable graphics.
    The issue doesn't happen if run individual test.
    I have not tested BurnInTest on a switchable graphics system. In saying this, the graphics system should still support these tests.
    - What grahics hardware are you using?
    - When under test, is your system using the discrete or integrated graphics card?
    - Does the problem occur if you are using the discrete graphics card (e.g. plugged into AC) and also the integrated graphics card?
    - Could you please send me a level 2 trace log file, *.trace, (set in Preferences->Logging), showing the test run with the error? You can email the *.trace files to the email address shown here:
    http://www.passmark.com/support/index.htm
