How can I get the slow drive threshold warning to work
    • 11112
    > I can't get the slow drive warning indicator
    > to work (that might be useful during my
    > Qualification Vibration Testing to check disk retries).
    The interface in this preferences window is slightly counter-intuitive and that was proabably the problem. You have to set the threshold *before* adding the drive to the list. To change the threshold you need to remove the drive from the list, enter a new threshold, then add it again. Once the threshold is set it should appear in the list.
    PassMark
