Announcement
No announcement yet.
"Low on memory" shows on Burin 5.3/ 6.0.
  • Filter
  • "Low on memory" shows on Burin 5.3/ 6.0.
    After test with below setting, it will pop up two kinds of "Low on memory" windows.
    1. From Microsoft windows:"Close programs to prevent information loss - Your computer is low on memory. Save your files and close these programs:BurnIn Test"
    2. From Burn-in software:"Low on memory. Test can not be completed."
    Test Environment
    Burn-in:Version 5.3/ 6.0
    OS:Windows embedded 7
    CPU:AMD eOntario 1.6GHz Dual code
    RAM:DDR3 2/4 G
    SATA FLASH:8G
    Test Configuration
    CPU Math:100%
    CPU SIMD:100%
    Memory(RAM):100%
    Disk:100%
    2D Graphics:100%
  • #2
    The memory test changed significantly between V5.3 and 6.0. Please test with the latest build of BurnInTest V6.0 here:
    http://passmark.com/download/bit_download.htm
    Please ensure that you are using the Standard memory test, rather than the Memory torture test (which can test the paging mechanism by overallocating memory).
    Please ensure that if you are using the Video memory test that you specify "Local video memory only", as this way the 2D video memory test will test the video memory and the RAM test will test the system memory.
