BIT 6 - Logs
  • JohnDorian
    • Nov 2010
    • 42
    BIT 6 - Logs
    When the BIT finishes, I need to be able to determine if it passed or failed. If it fails, I need to know why.
    But because of the way the test is formatted, it makes it difficult to find out the failures. I checked the log in normal text format and HTML and neither makes it very easy to determine the cause of failure.
    At the moment, I parsing the file and checking for "TEST RUN FAILED." If it's found, I fail the test and if not, I pass it. But I need details.
    So, is there a list of possible failures I could just look for? So the failure might say, "Memory test failure" or "error allocating ram", etc. If I had a list of possible errors, I could just look for those and that would work for me.
    The only tests I'm running are CPU, ODD, RAM, 2D/3D, and disks.
    All of the main errors are listed in the file BITErrorClassification.txt in the BurnInTest directory. They are also shown with a description in the User guide (and help file) in section 12.3 "Common Test Error Messages":
    http://www.passmark.com/ftp/BIT_Users_Guide_Ed7_0.pdf
    As these error messages are configurable, the strings could change.
    • JohnDorian
      • Nov 2010
      • 42
      Ah. I looked through the documentation, but I guess I missed that part. That should work perfectly.
      Thanks, Ian.
