BIT 6 Randomly Stopping
  • JohnDorian
    • Nov 2010
    • 42
    Sometimes when I run the BIT, it will stop after running for 50 minutes to an hour. When I check the log file, it will either say, "No operations..." for every test or it will say "No errors."
    The latter situation occurs most often and is quite puzzling. I can't figure out why it would stop but not have any errors messages.
    Does anyone have any ideas or know of any common issues related to this?
    Maybe you have set the auto stop time to 1 hour, or to a particular number of cycles that corresponds to abut 50min of testing.
    • JohnDorian
      • Nov 2010
      • 42
      I have it set to 60 minutes and 70 depending on the PC. So it shouldn't stop.
      But I think there's an issue in my code somewhere. For instance, the following log file is for a PC that is supposed to run for 30 minutes. Which it did, but it still popped up as if it failed.
      PassMark BurnInTest Log file - http://www.passmark.com
      Date: 12/30/11 09:20:30
      BurnInTest V6.0 Pro 1030
      (64-bit)Logging detail level: Result summary
      SYSTEM SUMMARY
      Windows Vista Home Premium Edition Service Pack 2 build 6002 (64-bit),
      1 x Intel(R) Core(TM)2 Duo CPU T6500 @ 2.10GHz,
      3.9GB RAM,
      Mobile Intel(R) 4 Series Express Chipset Family,
      CD-RW/DVDRW,
      GENERAL
      System Name: WANDA-PC
      CPU
      CPU Type: Intel(R) Core(TM)2 Duo CPU T6500 @ 2.10GHz
      Codename: Penryn
      CPUID: Family 6, Model 17, Stepping A, Revision R0
      Socket: PGA478/BGA479
      Lithography: 45nm
      Physical CPU's: 1
      Cores per CPU: 2
      Hyperthreading: Not capable
      CPU features: MMX SSE SSE2 SSE3 SSSE3 SSE4.1 DEP PAE Intel64
      Clock frequencies:
      Measured CPU speed: 2095.0 MHz
      Multiplier: x10.5
      Scalable Bus Speed: 199.5 MHz
      Front Side Bus: 798.1 MHz
      Cache per CPU package:
      L1 Instruction Cache: 2 x 32 KB
      L1 Data Cache: 2 x 32 KB
      L2 Cache: 1 x 2048 KB
      MEMORY
      Total Physical Memory: 3998MB
      Available Physical Memory: 2201MB
      RESULT SUMMARY
      Test Start time: Fri Dec 30 09:20:30 2011
      Test Stop time: Fri Dec 30 09:50:33 2011
      Test Duration: 000h 30m 03s
      Memory (RAM) 31 195 Billion PASS 0 No errors
      2D Graphics 15 15224 PASS 0 No errors
      3D Graphics 28 56361 PASS 0 No errors
      Optical disk (F 14 808 Million PASS 0 No errors
      Disk (C 2 18.174 Billion PASS 0 No errors
      TEST RUN PASSED
      SERIOUS ERROR SUMMARY FOR THE LAST TEST RUN
      So this one's on me. It sure is odd though =/
