BIT 6 - S.M.A.R.T. False Failure?
  • JohnDorian
    • Nov 2010
    • 42
    I had two units today that both failed for SMART Threshold exceeding condition detected.
    They were both new hard drives that were OS restored. On one unit, I had the tech replace the drive and do OS again. Afterwards, it failed again 48 minutes in. I didn't have him do anything to the other unit yet.
    The HDD is a Toshiba HDD and I've attached the log.
    PassMark BurnInTest Log file - http://www.passmark.com
    Date: 01/04/01 15:08:26
    BurnInTest V6.0 Pro 1030
    (64-bit)Logging detail level: Result summary
    SYSTEM SUMMARY
    Windows 7 Home Premium Edition build 7600 (64-bit),
    1 x Pentium(R) Dual-Core CPU T4300 @ 2.10GHz,
    2.9GB RAM,
    Mobile Intel(R) 4 Series Express Chipset Family,
    CD-RW/DVDRW,
    GENERAL
    System Name: HP-PC
    CPU
    CPU Type: Pentium(R) Dual-Core CPU T4300 @ 2.10GHz
    Codename: Penryn
    CPUID: Family 6, Model 17, Stepping A, Revision R0
    Socket: Socket P (47
    Lithography: 45nm
    Physical CPU's: 1
    Cores per CPU: 2
    Hyperthreading: Not capable
    CPU features: MMX SSE SSE2 SSE3 SSSE3 DEP PAE Intel64
    Clock frequencies:
    Measured CPU speed: 2095.1 MHz
    Multiplier: x10.5
    Scalable Bus Speed: 199.5 MHz
    Front Side Bus: 798.1 MHz
    Cache per CPU package:
    L1 Instruction Cache: 2 x 32 KB
    L1 Data Cache: 2 x 32 KB
    L2 Cache: 1 x 1024 KB
    MEMORY
    Total Physical Memory: 3003MB
    Available Physical Memory: 2026MB
    RESULT SUMMARY
    Test Start time: Thu Jan 04 15:08:26 2001
    Test Stop time: Thu Jan 04 15:17:27 2001
    Test Duration: 000h 09m 01s
    CPU 139 122 Billion PASS 0 No errors
    Memory (RAM) 4 20.135 Billion PASS 0 No errors
    2D Graphics 10 10906 PASS 0 No errors
    3D Graphics 9 18526 PASS 0 No errors
    Optical disk (E 4 717 Million PASS 0 No errors
    Disk (C 115 13.984 Billion FAIL 2 SMART Threshold exceeding condition detected.
    TEST RUN FAILED
    SERIOUS ERROR SUMMARY FOR THE LAST TEST RUN
    SERIOUS: 2001-01-04 15:17:23, Disk, SERIOUS: SMART Threshold exceeding condition detected. (x 2)
    Is this truly a failure or a false failure? It seems odd that 3 hard drives failed for the exact same thing at exactly the same time.
    Maybe download DiskCheckup and see which attribute has exceeded it threshold.
    http://www.passmark.com/products/diskcheckup.htm
    It might just a temperature warning, or something not so serious.
