BSOD when using Movie Maker or Cyberlink Power Director Dump file included
  • Boboule
    • Jan 2012
    System summary:
    Windows 7 Ultimate Edition Service Pack 1 build 7601 (64-bit),
    1 x AMD Athlon(tm) 64 X2 Dual Core Processor 6400+ [3215.3 MHz],
    3.7GB RAM,
    ATI Radeon HD 3200 Graphics,
    233GB HDD, 38GB HDD, 932GB HDD,
    CD-RW/DVDRW/BD-RE, CD-RW/DVDRW, CD/DVDRW,
    Motherboard Manufacturer: Gigabyte Technology Co., Ltd.
    Motherboard Name: GA-MA78GM-US2H
    Motherboard Version: x.x
    BIOS Manufacturer: Award Software International, Inc.
    BIOS Version: F8
    BIOS Release Date: 10/08/2009
    CPU:
    CPU manufacturer: AuthenticAMD
    CPU Type: AMD Athlon(tm) 64 X2 Dual Core Processor 6400+
    Codename: Windsor
    CPUID: Family F, Model 43, Stepping 3, Revision JH-F3
    Socket: AM2
    Lithography: 90nm
    Physical CPU's: 1
    Cores per CPU: 2
    Hyperthreading: Not capable
    CPU features: MMX 3DNow! SSE SSE2 SSE3 DEP PAE AMD64
    Clock frequencies:
    - Measured CPU speed: 3215.3 MHz
    Cache per CPU package:
    - L1 Instruction Cache: 2 x 64 KB
    - L1 data cache: 2 x 64 KB
    - L2 cache: 2 x 1024 KB
    - L3 cache: Not applicable
    Memory
    Total Physical Memory: 3838MB
    Available Physical Memory: 2396MB
    Memory devices:
    Slot 1:
    - 1GB DDR2 SDRAM PC2-6400
    - Kingston
    - SSTL 1.8V, Clk: 400.0MHz, Timings 6-6-6-18 (@ Max. freq.)
    Slot 2:
    - Kingston
    Slot 3:
    - Kingston
    Slot 4:
    - Kingston
    Virtual memory: C:\pagefile.sys (allocated base size 3838MB)
    Graphics
    Chip Type: ATI display adapter (0x9610)
    DAC Type: Internal DAC(400MHz)
    Memory: 256MB
    BIOS: BK-ATI VER010.087.000.001.000000
    Driver provider: ATI Technologies Inc.
    Driver version: 8.641.0.0
    Driver date: 7-30-2009
    Monitor 1: 1920x1080x32 59Hz (Primary monitor)
    Disk volumes
    A: Floppy
    C: Local drive, NTFS, (128.00GB total, 100.67GB free)
    D: Optical drive
    E: Optical drive
    F: Optical drive
    G: Local drive, FreeAgent Drive, NTFS, (232.88GB total, 190.66GB free)
    H: Local drive, FAT32, (37.40GB total, 34.47GB free)
    I: Local drive, FAT32, (37.11GB total, 26.87GB free)
    J: Local drive, MUSIC, NTFS, (19.10GB total, 13.46GB free)
    K: Local drive, PICTURES, NTFS, (19.18GB total, 14.05GB free)
    L: Local drive, Nas 2, NTFS, (437.27GB total, 289.35GB free)
    M: Local drive, Nas 2 Part 2, NTFS, (494.24GB total, 457.23GB free)
    N: Local drive, New Volume, NTFS, (104.88GB total, 67.49GB free)
    W: Networked, Volume_2, NTFS
    X: Networked, Volume_1, NTFS
    Y: Networked, Drive(A5), NTFS
    Z: Networked, Drive(A1), NTFS
    Disk drives
    Disk drive: Model ST3250310AS ATA Device (Size: 232.88GB)
    Disk drive: Model NDAS Maxtor 6E040L0 SCSI Disk Device (Size: 38.28GB)
    Disk drive: Model NDAS SAMSUNG HD103SI SCSI Disk Device (Size: 931.51GB)
    Disk drive: Model Seagate FreeAgentDesktop USB Device (Size: 232.88GB)
    Disk drive: Model WDC WD80 0BB-00CAA1 USB Device (Size: 74.53GB)
    Optical drives
    E: ATAPI iHBS112 2 (CD-RW/DVDRW/BD-RE)
    D: HL-DT-ST DVDRAM GH20NS10 (CD-RW/DVDRW)
    F: LITE-ON SOHW-1673SU (CD/DVDRW)
    Network
    Realtek RTL8168C(P)/8111C(P) Family PCI-E Gigabit Ethernet NIC (NDIS 6.20) (Speed: 1Gb/s) (MAC: 00:1F07:92:2
    Ports
    Communications Port: COM1 - RS232 Serial Port (max Baud rate: 115200)
    Parallel port: LPT1
    Keyboard Port: PS/2 connector
    Mouse Port: PS/2 connector
    USB
    Standard OpenHCD USB Host Controller
    - CHICONY USB NetVista Full Width Keyboard
    Standard Enhanced PCI to USB Host Controller
    - Oxford Semiconductor Ltd OXSEMI Mass Storage (SN: 6QE11YG1)
    - (SN: 5ABAE5C0)
    VIA Rev 5 or later USB Universal Host Controller
    - Logitech USB Receiver
    VIA USB Enhanced Host Controller
    - Iomega Iomega HDD USB 2.0 Drive (SN: DEF10CB9E2A5)
    - USB2.0 External Mass Storage Device (SN: DEF10B38BCD5)
    - Canon MP240 series (SN: C2757E)
    RESULT SUMMARY
    Test Start time: Tue Jan 10 10:05:42 2012
    Test Stop time: Tue Jan 10 10:20:44 2012
    Test Duration: 000h 15m 02s
    Temperature HDD 0 (ST3250310AS ATA Device) (Min/Current/Max): 33.0C / 34.0C / 34.0C
    Temperature HDD 2 (Seagate FreeAgentDesktop USB Device) (Min/Current/Max): NA / NA / NA
    Temperature HDD 3 (NDAS SAMSUNG HD103SI SCSI Disk Device) (Min/Current/Max): 27.0C / 29.0C / 29.0C
    Temperature HDD 4 (NDAS Maxtor 6E040L0 SCSI Disk Device) (Min/Current/Max): 31.0C / 42.0C / 42.0C
    Test Name Cycles Operations Result Critical Serious Warning Information
    CPU 60 187 Billion PASS 0 0 0 0
    Memory (RAM) 18 74.321 Billion PASS 0 0 0 0
    2D Graphics 7 7121 PASS 0 0 0 0
    Temperature - - PASS 0 0 0 0
    Optical disk (D 0 0 FAIL 0 30 0 0
    Optical disk (E 0 0 FAIL 0 30 0 0
    Optical disk (F 0 0 FAIL 0 30 0 0
    Sound 9 16.196 Million PASS 0 0 0 0
    Disk (C 3 9.088 Billion PASS 0 0 0 0
    Network 1 3 128320 PASS 0 0 0 0
    TEST RUN FAILED
    DETAILED EVENT LOG
    LOG NOTE: 2012-01-10 10:05:42, Status, Main Tests started
    LOG NOTE: 2012-01-10 10:05:43, CPU, SSE4.1 SSE4.2 SSE4a test(s) selected, but CPU feature not detected
    SERIOUS: 2012-01-10 10:05:44, Optical disk, F: Error while searching for files on optical data disk
  • Tripredacus
    • Feb 2009
    • 40
    It looks like you chose to do a CD test but didn't have any media in your drives...
      Update your video drivers to start with.
