system hang if we
  • wayneh
    • Nov 2009
    • 24
    system hang if we
    Hi Sir,
    I am running the test with BurnIn V7.0(1009), it occurs system hang when running the test.
    Would you help to check this issue? Thanks.
    here is my test result:
    BurnIn V7.0(1009) with these test items, it occurs hang.
    CPU, Optical Drives, RAM, 2D Graphics, 3D Graphics, Disk, Sound, Network.
    BurnIn V7.0(1009) with these test items, it does not occur hang.
    CPU, Optical Drives, RAM, 2D Graphics, Disk, Sound, Network.
    BurnIn V6.0 with these test items, it does not occur hang.
    Test configuration:
    Platform:Intel Rompley+Patsburg
    Video card: Nvidia Quadro 400
    OS: Windows 7 64bit
    I would suggest trying to reduce the set of tests you are running at the same time to isolate the problem. e.g. try the 3D test by itself, or 3D and RAM.
