Setting Block Size in Disk Test Preferences?
  • MeHardy
    • Mar 2012
    Windows 7 Pro
    BurnIn V7.0 Pro
    Production Environment
    I need to set the Disk Test Preferences Block size to 520. The standard drop down menu has 512. Can I use the SETDISK COMMAND to specify a 520 block size?
    Yes you can. You can verify the block size after running the script by checking the block size of the disk in Preferences.
