Is there a way to uncheck a disk via script?
  • shayne
    • Feb 2017
    So we can set to test a disk via SETDISK, what about the removing a disk?
    No there currently isn't a way to remove a disk once it's been added via a scripting command, however all the disks can be removed by loading a default/empty (that has had all the disks unchecked) config file with the LOAD command.
