If the virtual memory enable in OS is must for BIT?
  • henryjan
    • Mar 2017
    Greeting,
    The 2D failure (Video memory corruption) & 3D failure (The 3D test was interrupted) were happened with virtual memory disable.
    BIT worked well when the virtual memory enable.
    Thanks a lot.
    My system configuration is listed as below:
    i7-6700K
    8GB DDR4 2133 x2
    128GB SSD by SATA Gen.3
    NV 1070 Gfx w/ 8GB GDDR5
    OS: Win7 embedded (the virtual memory default setting is disable)
    BIT runs items: 2D / 3D / CPU / Memory / Temperature / Video Playback
    The causes for the message "The 3D test was interrupted" are detailed here.
    Likely your video card driver crashes once it gets low on RAM.
    So yes, you should probably turn on the paging file if you are using the RAM test and the 3D test at the same time.
