".bits" scripts for BurnIn V6.0 Pro doesn't run when using DOS commands
  • avinash2503
    • May 2012
    Hi
    I am not able to execute a script for BurnIn Test 6.0 through a DOS command line. Here is the DOS command I enter.
    > bit.exe -s "Script1.bits"
    where Script1.bits is
    # Load script
    LOAD "PassMark_RAM_test_1min.bitcfg"
    SETDURATION 1
    RUN CONFIG
    EXIT
    The DOS command just opens BurnIn Test 6.0 but doesnt execute the script as mentioned in the help manual. The script successfully executes if I execute it through the BurnIn Test menu. Both the .bits and .bitcfg files are in the same directory as bit.exe.
    Am I missing something here?
    I also know that we could use certain command line parameters in the DOS command line interface to start stress with the required configuration. But is there a way(command line parameter) to close BurnIn Test once a test has been completed (similar to the EXIT command in the script file)?
    Are you using the final V6 release or some earlier patch?
    What folder are you in when you enter in the command line instruction?
    Did you try using a full path to the Script1.bits file?
    Also try capital -S, I can't remember if lower case was acceptable.
