BIT 7 x64 on Intel Q77 Chipset
  • stylemongo
    • Jun 2012
    I have the problem, that BIT 7 consumes all free RAM during run, even when i disable the Memory test, this leas Windows to bring me an Error that there is no Free RAM left. The Spec are: Intel DQ77KM Mobo, i3-2100 CPU, 2x 4GB Kingston DDR3-1333 RAM, OS: Win7 x64 Pro.
    an Ideas?
    What tests are you running in BurnInTest.
    How long does it run before you get the no free RAM warning?
    How large is your swap file?
    The RAM test is the only test that should be using significant amounts of RAM.
