Upgrade of BIT 4.x to BIT 5.x
  • EKF
    • Jun 2005
    • 16
    I just noticed that the new major version of BIT is available.
    We use more than one license, do we need to purchase an upgrade for every license, or is one enough for all of them?
    We currently use one key for all license, and it seems that we will get a new one after the purchasing of the upgrade.
    EKF
    If you purchased a previous version of BurnInTest on (or after) the 24th of August 2005, then you are eligible for a free upgrade to BurnInTest V5. If you purchased BurnInTest prior to this date, then you will need to purchase an upgrade.
    If you purchase an upgrade, then you need to upgrade each license. e.g. if you have 3 old licenses, then you should enter 3 as the quantity in the upgrade form. There are discounts for volume upgrades.
