BurnInTest 7.0 - Maximum Heat Test
  • brentmd
    • Aug 2011
    • 13
    BurnInTest Team,
    When you run the maximum heat test and it tells you to disable all other tests. Does that mean uncheck all boxes in the CPU tab except "Maximum Heat Test" and uncheck all other hardware tests? OR does it mean uncheck all other hardware tests and check "Maximum Heat Test", but leave all other options checked under CPU tab.
    Thanks,
    Brent
    To run a test to generate the maximum CPU heat possible via BurnInTest, you can just run QuickTest->Maximum CPU test.
    Or you can configure similar by unchecking all boxes in the CPU tab except "Maximum Heat Test" and uncheck all other hardware tests.
