Low Memory Failure during PassMark Benchmark
  • taohung
    • Aug 2012
    • 7
    Hi, all,
    we encounter an issue that a error reports with with 2GB memory after run BrunInTest v7.0 Pro the test about 1 hour 15 minutes.
    But, the test result is pass with 4GB memory.
    error message:close program to prevent information loss
    Do you see the same issue? if any comment, please share with us. Thx.
    My guess would be that some device driver on your machine has a memory leak.
    So after running for a while there is no more RAM available.
    Try running the tests 1 at a time while monitoring the RAM usage.
    There are a couple of device drivers that we know have this problem, but there are probably many others that we don't know about as well.
    The Intel HD video card driver has a problem. See this post for details,
    http://www.passmark.com/forum/showth...el-HD-graphics
    The Conexant 20672 SmartAudio HD, sound card drivers also have a problem. See this post for details.
    http://www.passmark.com/forum/showth...-via-sequencer
    • taohung
      • Aug 2012
      • 7
      Is the failure caused by a specific app ot driver?
      Does the failure impact end user?
        This can't be answered until you get to the root cause of the problem.
