Burn In Test script question
  • ArchNemesis
    • Oct 2012
    hello all,
    i'm new to writing a script file for the BIT application.
    i am using BIT v6.0
    am I able to write in my script.bits file which specific test(s) to run simultaneously without a .bitcfg to refer to?
    i also want to set each duty cycle to 100 of the chosen test I want to be runned.
    _______________________
    SETTECHNICIAN
    SETSERIAL
    SETCUSTOMER
    SETMACHINETYPE
    work just fine.
    i know that:
    RUN CD
    RUN CPU
    RUN DISK
    run each test individually
    and:
    RUN CONFIG
    runs all the tests simultaneously?
    my .bitcfg only contains changed preferences from the "preferences tab" not from test cycles, etc.
    i want to be able to set the " test cycle, duration, duty cycle " through the script file. is it possible?
    At least in V7 this is possible. I think these commands were also in the older V6 release, but can't remember exactly.
    See the help file and the following script commands,
    SETCYCLES
    SETDURATION
    SETDUTYCYCLE
    Help file
    http://www.passmark.com/ftp/BIT_Users_Guide_Ed7_0.pdf
    • ArchNemesis
      • Oct 2012
      Thanks for replying, David.
      how do i run selected tests simultaneously only?
      ie. i want only CPU, DISK, CD, VIDEO, 2D, RAM, SOUND to run only? all at the same time, without using a " LOAD XXXXXX.bitcfg " ?
