flash drive and butterfly seeking
  • Dannycycu
    • Nov 2012
    • 34
    Hi all,
    I ran a disk test using 'BurnInTest script method, but each time then ran the next pattern after the "butterfly seeking pattern" will appear "test file could not be created. Check access privileges." error message, and cause the I / O device wrong, causing the test interrupt, I see my flash drive, there is still a "BurnIn Test test file", but I can’t open this case why it happened?I ran a disk test using 'BurnInTest script method, but each time then ran the next pattern after the "butterfly seeking pattern" will appear "test file could not be created. Check access privileges." error message, and cause the I / O device wrong, causing the test interrupt, I see my flash drive, there is still a "BurnIn Test test file", but I can’t open this case why it happened?
    Thanks!
    Does the user you're running as have permission to create/read/write and delete files on the USB drive (that is the USB drive isn't filling up and BurnInTest doesn't have permissions to delete the test files)?
    Could you please post the script file you are using, so far we haven't seen see any issues testing to a USB drive when running through the available disk test patterns.
    • Dannycycu
      • Nov 2012
      • 34
      Thank you so quick to answer my question, Tim.
      I want my users should have permission to create / read / write, and delete files in my USB, drive, once again I described in detail the point of my question, for example, 5% of my file size is set to run a pattern. when I flash storage reaches 95% full, the software will automatically do the deleting and re-starting, but the problem is that when I ran Default (Cyclic) mode, after running a pattern will appear each time at the finish "Butterfly seeking" Test file could not be created.Check access privileges "error occurs
      The same as the original, the same process, with a batch of products, any four of the two will happen.
      The following command is a script file, I used to hope you use this file as a reference to help solve my problem
      LOOP 10000
      SETCYCLES 19
      SETDURATION 0
      SETDISK DISK H: MODE sequential FILE 5 BLOCK 1024 SEEK 100
      RUN DISK
      SETCYCLES 19
      SETDURATION 0
      SETDISK DISK H: MODE seeking FILE 5 BLOCK 1024 SEEK 100
      RUN DISK
      SETCYCLES 19
      SETDURATION 0
      SETDISK DISK H: MODE highlow FILE 5 BLOCK 1024 SEEK 100
      RUN DISK
      SETCYCLES 1
      SETDURATION 0
      SETDISK DISK H: MODE butterfly FILE 5 BLOCK 1024 SEEK 100
      RUN DISK
      SETCYCLES 19
      SETDURATION 0
      SETDISK DISK H: MODE binary1 FILE 5 BLOCK 1024 SEEK 100
      RUN DISK
      SETCYCLES 19
      SETDURATION 0
      SETDISK DISK H: MODE binary2 FILE 5 BLOCK 1024 SEEK 100
      RUN DISK
      SETCYCLES 19
      SETDURATION 0
      SETDISK DISK H: MODE zeros FILE 5 BLOCK 1024 SEEK 100
      RUN DISK
      SETCYCLES 19
      SETDURATION 0
      SETDISK DISK H: MODE ones FILE 5 BLOCK 1024 SEEK 100
      RUN DISK
      SETCYCLES 19
      SETDURATION 0
      SETDISK DISK H: MODE random FILE 5 BLOCK 1024 SEEK 100
      RUN DISK
      Thanks!
        There doesn't seem to be any problem with the script file, we've run it ok on a USB drive here and didn't encounter any issues after several loops.
        There should be more information with the specific error code from when the file failed to create saved in the BurnInTest log file, it should be the line just after the "Write File - File name:" or "Write block - File name:" line, what was this error code?
        Also, if you go into the logging options for BurnInTest and change the trace file detail level to activity trace 2 more information about what was happening when when the error occurs should be logged in .trace files in the log directory.
        • Dannycycu
          • Nov 2012
          • 34
          I have kept each test BurnIn Test log file, I'll post the error code message for your reference.
          datalog:
          WARNING: 2012-11-06 16:12:18, Disk, H: Test file could not be created. Check access privileges.
          LOG NOTE: 2012-11-06 16:12:18, Disk, Write File - File name: H: \ BurnInTest test files \ ~ bittestH00001
          LOG NOTE: 2012-11-06 16:12:18, Disk, because the I / O device error, so the request can not be executed. (1117)
          LOG NOTE: 2012-11-06 16:12:24, Disk, Disk Error (H : Test file could not be created. Check access privileges. In Cycle 0 with pattern Binary data pattern 1 (1010)
          trace:
          LOG NOTE: 2012-11-06 16:12:18, Disk, Error writing file: H: \ BurnInTest test files \ ~ bittestH00001, size: 762314752, blocksize 1048576
          LOG NOTE: 2012-11-06 16:12:24, Disk, Disk free space: 14543MB, disk size: 14543MB
          LOG NOTE: 2012-11-06 16:12:24, Disk, Mem Tot: 1851MB [870MB], page: 3702MB [2432MB], virt: 2047MB [1827MB], ext virt: [0MB], 52
          When this error condition occurs, the only solution is the only way to resolve the storage device do unplug and re-plug the action.
          Thanks.
            Thanks for posting the error code, for some reason the actual error message appears garbled (unless it has been translated into English) as it should be "The request could not be performed because of an I/O device error."
            Given this error message it would appear to be a faulty USB device.
            • Dannycycu
              • Nov 2012
              • 34
              Thank you for the reply, some error code really is not in English, thank you to understand the content of my interpretation.
              So you think it is a faulty flash storage devices, but only in the running after the butterfly seeking pattern to appear this error,if I use the script according to Default (Cyclic) sequence but no butterfly seeking pattern ran a long period of time did not problems.
              How does the "Butterfly seeking" operate mode?
              What does "Butterfly seeking" can help me to verify the characteristics of flash storage devices?
              Please help answer my questions,thanks.
              • Dannycycu
                • Nov 2012
                • 34
                I set windows explorer ran no problems with butterfly seeking pattern 60 cycles alone, How do I judge my flash storage is a faulty?
                • Dannycycu
                  • Nov 2012
                  • 34
                  Should say 9 pattern (sequential, seeking highlow, butterfly, binary1, binary2, zeros, ones, and random), I ran alone 60 cycles are not the problem.
                  Thanks.
                  • Dannycycu
                    • Nov 2012
                    • 34
                    I read the "Butterfly seeking" explanation of "Test Descriptions" section of the BurnInTest help file in the "Disk test suite" topic.But I don't understand file described the work which the test behavior.Can be described in another way?
                    Please help answer my questions, thanks.
                      Butterfly seeking works by detecting the hard disk geometry (number of cylinders etc) and then seeking between cylinder 0 and cylinder X and back to cylinder 0. This is repeated the user specified ‘seek count’ times (from the preferences window), before X is incremented by 1. This is repeated until the last cylinder on the Volume is reached. The number of operations reported refers to the number of combined Seek/Read operations.
                      Notes
                      (1) that this test is only supported in Windows XP and above on non-Floppy, non-optical drives.
                      (2) Performing a seek in many cases does not move the disk driver head, to ensure the disk drive head is moved to the seek position, a small read (of the Sector size) is done at each seek position. Also, incremental offsets of the sector size are used for the ‘X’ seek and the return to ‘0’ seek, to ensure that the disk drive cache is overflowed and physical disk seeks consistently occur (once the disk cache has overflowed).
                      (3) Disk drive geometry may be faked or translated by hard disks/ device drivers and may not be the actual drive geometry.
                      (4) The Cylinders, track and sector size used are typically logical values provided by the hard disk.
                      (5) Up to 8 different physical extents per Volume (or Drive letter) are supported in the butterfly-seeking test.
                      (6) As with other disk tests, if a physical disk is partitioned into multiple volumes (drives) and testing is simultaneously carried out on these volumes, the nature of the test will change. In the case of Butterfly seeking, the movement of the physical disk drive head will not reflect butterfly seeking, but something between butterfly seeking and random seeking, as the seeks for volume 1 go from its logical cylinder 0 to X and the seeks for volume 2 go from its logical cylinder 0 to Y are mixed in time.
                      (7) Some disk drive device drivers do not support the supply of disk geometry information that is needed for this test.
                      ( The Raw disk test option does not support the Butterfly seeking test mode and will be skipped.
                      (9) The default setting is to cycle between the patterns. In this case a new pattern will be selected each time the disk has reached the BurnInTest ‘full’ level. Where the disk drive is a floppy, CD, DVD, or the operating system is Vista (and later) and the user is not running BurnInTest with 'elevated' administrator privileges, then Butterfly seeking will be skipped in the Cyclic testing and a log message reported.
                      This test option was designed mostly for traditional hard drives with a moving head. Solid state drives don't have moving parts, but the test still works.
                      Solid state (including flash drives) still logically divide up their capacity into cylinders, tracks & sectors. So on a SSD, like a normal drive, you will effectively be reading data from across the surface of the drive in the pastern described above.
                      • Dannycycu
                        • Nov 2012
                        • 34
                        Pass level 2 activity trace log:
                        LOG NOTE: 2012-11-09 11:59:11, Scripting on stop interim, errors = 0
                        LOG NOTE: 2012-11-09 11:59:16, Script, SETCYCLES 1
                        LOG NOTE: 2012-11-09 11:59:16, Script, SETDURATION 0
                        LOG NOTE: 2012-11-09 11:59:16, Script, SETDISK DISK H: MODE butterfly FILE 5 BLOCK 1024 SEEK 100
                        LOG NOTE: 2012-11-09 11:59:16, Script, RUN DISK
                        LOG NOTE: 2012-11-09 11:59:16, StartTests
                        LOG NOTE: 2012-11-09 11:59:17, Status, Main Tests started
                        LOG NOTE: 2012-11-09 11:59:17, Perform test: Disk (H : ) at 100%
                        LOG NOTE: 2012-11-09 11:59:17, Disk (H : ), Starting test
                        LOG NOTE: 2012-11-09 11:59:19, Disk paging file: H 1
                        LOG NOTE: 2012-11-09 11:59:19, Disk paging file B: HC
                        LOG NOTE: 2012-11-09 11:59:19, Disk Win install: HC
                        LOG NOTE: 2012-11-09 11:59:19, Disk, Disk free space: 14543MB, disk size: 14543MB
                        LOG NOTE: 2012-11-09 11:59:19, Disk, GetVolumeExtents: Drive H: \, Volume: \ \? \ Volume {b0148906-0c62-11e2-8e97-6cf049daeb28}
                        LOG NOTE: 2012-11-09 11:59:19, Disk, GetVolumeExtents: IOCTL_VOLUME_GET_VOLUME_DISK_EXTENTS success
                        LOG NOTE: 2012-11-09 11:59:19, Disk, GetVolumeExtents: IOCTL_VOLUME_GET_VOLUME_DISK_EXTENTS data returned 32
                        LOG NOTE: 2012-11-09 11:59:19, Disk, GetDriveGeometry: Drive H: (0 of 1 extents)
                        LOG NOTE: 2012-11-09 11:59:19, Disk, GetDriveGeometry: Open \ \. \ PhysicalDrive2
                        LOG NOTE: 2012-11-09 11:59:19, Disk, GetDriveGeometry Ex: Query Device driver
                        LOG NOTE: 2012-11-09 11:59:19, Disk, GetDriveGeometry: Drive H: (Extent size: 15267234304, Tracks / C: (255), Sectors / T: (63), Bytes / S: (512)
                        LOG NOTE: 2012-11-09 12:00:24, System Event, 523336 - Information, Event ID: 0x0000077D, Source: EventLog (Generated time: 2012-11-09 12:00:24)
                        LOG NOTE: 2012-11-09 12:00:24, System Event, 523336 - Description: The system uptime is 236208 seconds.
                        LOG NOTE: 2012-11-09 12:11:20, Disk, GetVolumeExtents: Drive H: \, Volume: \ \? \ Volume {b0148906-0c62-11e2-8e97-6cf049daeb28}
                        LOG NOTE: 2012-11-09 12:11:20, Disk, GetVolumeExtents: IOCTL_VOLUME_GET_VOLUME_DISK_EXTENTS success
                        LOG NOTE: 2012-11-09 12:11:20, Disk, GetVolumeExtents: IOCTL_VOLUME_GET_VOLUME_DISK_EXTENTS data returned 32
                        LOG NOTE: 2012-11-09 12:11:20, Disk, GetDriveGeometry: Drive H: (0 of 1 extents)
                        LOG NOTE: 2012-11-09 12:11:20, Disk, GetDriveGeometry: Open \ \. \ PhysicalDrive2
                        LOG NOTE: 2012-11-09 12:11:20, Disk, GetDriveGeometry Ex: Query Device driver
                        LOG NOTE: 2012-11-09 12:11:20, Disk, GetDriveGeometry: Drive H: (Extent size: 15267234304, Tracks / C: (255), Sectors / T: (63), Bytes / S: (512)
                        LOG NOTE: 2012-11-09 12:11:20, StopTests [3]
                        LOG NOTE: 2012-11-09 12:11:20, Test run stopping - step 0.0. 0: 0 of 1
                        LOG NOTE: 2012-11-09 12:11:24, Disk (H : ), Stopping test
                        LOG NOTE: 2012-11-09 12:11:26, Status, Test run stopped
                        LOG NOTE: 2012-11-09 12:11:26, Scripting on stop interim, errors = 0
                        LOG NOTE: 2012-11-09 12:11:31, Script, SETCYCLES 19
                        LOG NOTE: 2012-11-09 12:11:31, Script, SETDURATION 0
                        LOG NOTE: 2012-11-09 12:11:31, Script, SETDISK DISK H: MODE binary1 FILE 5 BLOCK 1024 SEEK 100
                        LOG NOTE: 2012-11-09 12:11:31, Script, RUN DISK
                        LOG NOTE: 2012-11-09 12:11:31, StartTests
                        LOG NOTE: 2012-11-09 12:11:32, Status, Main Tests started
                        LOG NOTE: 2012-11-09 12:11:32, Perform test: Disk (H : )at 100%
                        LOG NOTE: 2012-11-09 12:11:32, Disk (H : ), Starting test
                        LOG NOTE: 2012-11-09 12:11:33, Disk paging file: H 1
                        LOG NOTE: 2012-11-09 12:11:33, Disk paging file B: HC
                        LOG NOTE: 2012-11-09 12:11:33, Disk Win install: HC
                        LOG NOTE: 2012-11-09 12:11:33, Disk, Disk free space: 14543MB, disk size: 14543MB
                        LOG NOTE: 2012-11-09 12:11:33, Disk, Writing file: H: \ BurnInTest test files \ ~ bittestH00001, size: 762314752, block size: 1048576
                        LOG NOTE: 2012-11-09 12:11:33, Disk, WriteFile - allocating data buffer: H: \ BurnInTest test files \ ~ bittestH00001
                        LOG NOTE: 2012-11-09 12:11:33, Disk, WriteFile - creating file: H: \ BurnInTest test files \ ~ bittestH00001
                        LOG NOTE: 2012-11-09 12:11:33, Disk, WriteFile - creating data pattern: H: \ BurnInTest test files \ ~ bittestH00001
                        LOG NOTE: 2012-11-09 12:11:33, Disk, WriteFile - write file header: H: \ BurnInTest test files \ ~ bittestH00001
                        LOG NOTE: 2012-11-09 12:11:34, Disk, WriteFile - write file remainder: H: \ BurnInTest test files \ ~ bittestH00001
                        LOG NOTE: 2012-11-09 12:12:01, Disk, WriteFile - leaving: H: \ BurnInTest test files \ ~ bittestH00001
                        LOG NOTE: 2012-11-09 12:12:01, Disk, Verifying file: H: \ BurnInTest test files \ ~ bittestH00001, size: 762314752, block size: 1048576
                        LOG NOTE: 2012-11-09 12:12:20, Disk, Disk free space: 13816MB, disk size: 14543MB
                        LOG NOTE: 2012-11-09 12:12:20, Disk, Mem Tot: 1851MB [1123MB], page: 3702MB [2827MB], virt: 2047MB [1828MB], ext virt: [0MB], 39
                        LOG NOTE: 2012-11-09 12:12:20, Disk, Writing file: H: \ BurnInTest test files \ ~ bittestH00002, size: 762314752, block size: 1048576
                        LOG NOTE: 2012-11-09 12:12:20, Disk, WriteFile - allocating data buffer: H: \ BurnInTest test files \ ~ bittestH00002
                        LOG NOTE: 2012-11-09 12:12:20, Disk, WriteFile - creating file: H: \ BurnInTest test files \ ~ bittestH00002
                        LOG NOTE: 2012-11-09 12:12:20, Disk, WriteFile - creating data pattern: H: \ BurnInTest test files \ ~ bittestH00002
                        LOG NOTE: 2012-11-09 12:12:20, Disk, WriteFile - write file header: H: \ BurnInTest test files \ ~ bittestH00002
                        LOG NOTE: 2012-11-09 12:12:20, Disk, WriteFile - write file remainder: H: \ BurnInTest test files \ ~ bittestH00002
                        LOG NOTE: 2012-11-09 12:12:47, Disk, WriteFile - leaving: H: \ BurnInTest test files \ ~ bittestH00002
                        LOG NOTE: 2012-11-09 12:12:47, Disk, Verifying file: H: \ BurnInTest test files \ ~ bittestH00002, size: 762314752, block size: 1048576
                        LOG NOTE: 2012-11-09 12:13:05, Disk, Disk free space: 13089MB, disk size: 14543MB
                        LOG NOTE: 2012-11-09 12:13:05, Disk, Mem Tot: 1851MB [1123MB], page: 3702MB [2827MB], virt: 2047MB [1828MB], ext virt: [0MB], 39
                        LOG NOTE: 2012-11-09 12:13:05, Disk, Writing file: H: \ BurnInTest test files \ ~ bittestH00003, size: 762314752, block size: 1048576
                        LOG NOTE: 2012-11-09 12:13:05, Disk, WriteFile - allocating data buffer: H: \ BurnInTest test files \ ~ bittestH00003
                        LOG NOTE: 2012-11-09 12:13:05, Disk, WriteFile - creating file: H: \ BurnInTest test files \ ~ bittestH00003
                        LOG NOTE: 2012-11-09 12:13:05, Disk, WriteFile - creating data pattern: H: \ BurnInTest test files \ ~ bittestH00003
                        LOG NOTE: 2012-11-09 12:13:05, Disk, WriteFile - write file header: H: \ BurnInTest test files \ ~ bittestH00003
                        LOG NOTE: 2012-11-09 12:13:06, Disk, WriteFile - write file remainder: H: \ BurnInTest test files \ ~ bittestH00003
                        LOG NOTE: 2012-11-09 12:13:32, Disk, WriteFile - leaving: H: \ BurnInTest test files \ ~ bittestH00003
                        LOG NOTE: 2012-11-09 12:13:32, Disk, Verifying file: H: \ BurnInTest test files \ ~ bittestH00003, size: 762314752, block size: 1048576
                        LOG NOTE: 2012-11-09 12:13:51, Disk, Disk free space: 12362MB, disk size: 14543MB
                        LOG NOTE: 2012-11-09 12:13:51, Disk, Mem Tot: 1851MB [1123MB], page: 3702MB [2827MB], virt: 2047MB [1828MB], ext virt: [0MB], 39
                        LOG NOTE: 2012-11-09 12:13:51, Disk, Writing file: H: \ BurnInTest test files \ ~ bittestH00004, size: 762314752, block size: 1048576
                        LOG NOTE: 2012-11-09 12:13:51, Disk, WriteFile - allocating data buffer: H: \ BurnInTest test files \ ~ bittestH00004
                        LOG NOTE: 2012-11-09 12:13:51, Disk, WriteFile - creating file: H: \ BurnInTest test files \ ~ bittestH00004
                        LOG NOTE: 2012-11-09 12:13:51, Disk, WriteFile - creating data pattern: H: \ BurnInTest test files \ ~ bittestH00004
                        LOG NOTE: 2012-11-09 12:13:51, Disk, WriteFile - write file header: H: \ BurnInTest test files \ ~ bittestH00004
                        LOG NOTE: 2012-11-09 12:13:51, Disk, WriteFile - write file remainder: H: \ BurnInTest test files \ ~ bittestH00004
                        LOG NOTE: 2012-11-09 12:14:17, Disk, WriteFile - leaving: H: \ BurnInTest test files \ ~ bittestH00004
                        LOG NOTE: 2012-11-09 12:14:17, Disk, Verifying file: H: \ BurnInTest test files \ ~ bittestH00004, size: 762314752, block size: 1048576
                        LOG NOTE: 2012-11-09 12:14:36, Disk, Disk free space: 11635MB, disk size: 14543MB
                        LOG NOTE: 2012-11-09 12:14:36, Disk, Mem Tot: 1851MB [1122MB], page: 3702MB [2827MB], virt: 2047MB [1828MB], ext virt: [0MB], 39
                        LOG NOTE: 2012-11-09 12:14:36, Disk, Writing file: H: \ BurnInTest test files \ ~ bittestH00005, size: 762314752, block size: 1048576
                        LOG NOTE: 2012-11-09 12:14:36, Disk, WriteFile - allocating data buffer: H: \ BurnInTest test files \ ~ bittestH00005
                        LOG NOTE: 2012-11-09 12:14:36, Disk, WriteFile - creating file: H: \ BurnInTest test files \ ~ bittestH00005
                        LOG NOTE: 2012-11-09 12:14:36, Disk, WriteFile - creating data pattern: H: \ BurnInTest test files \ ~ bittestH00005
                        LOG NOTE: 2012-11-09 12:14:36, Disk, WriteFile - write file header: H: \ BurnInTest test files \ ~ bittestH00005
                        LOG NOTE: 2012-11-09 12:14:36, Disk, WriteFile - write file remainder: H: \ BurnInTest test files \ ~ bittestH00005
                        LOG NOTE: 2012-11-09 12:15:02, Disk, WriteFile - leaving: H: \ BurnInTest test files \ ~ bittestH00005
                        LOG NOTE: 2012-11-09 12:15:02, Disk, Verifying file: H: \ BurnInTest test files \ ~ bittestH00005, size: 762314752, block size: 1048576
                        LOG NOTE: 2012-11-09 12:15:21, Disk, Disk free space: 10908MB, disk size: 14543MB
                        LOG NOTE: 2012-11-09 12:15:21, Disk, Mem Tot: 1851MB [1122MB], page: 3702MB [2827MB], virt: 2047MB [1828MB], ext virt: [0MB], 39
                        LOG NOTE: 2012-11-09 12:15:21, Disk, Writing file: H: \ BurnInTest test files \ ~ bittestH00006, size: 762314752, block size: 1048576
                        LOG NOTE: 2012-11-09 12:15:21, Disk, WriteFile - allocating data buffer: H: \ BurnInTest test files \ ~ bittestH00006
                        LOG NOTE: 2012-11-09 12:15:21, Disk, WriteFile - creating file: H: \ BurnInTest test files \ ~ bittestH00006
                        LOG NOTE: 2012-11-09 12:15:21, Disk, WriteFile - creating data pattern: H: \ BurnInTest test files \ ~ bittestH00006
                        LOG NOTE: 2012-11-09 12:15:21, Disk, WriteFile - write file header: H: \ BurnInTest test files \ ~ bittestH00006
                        LOG NOTE: 2012-11-09 12:15:21, Disk, WriteFile - write file remainder: H: \ BurnInTest test files \ ~ bittestH00006
                        LOG NOTE: 2012-11-09 12:15:47, Disk, WriteFile - leaving: H: \ BurnInTest test files \ ~ bittestH00006
                        LOG NOTE: 2012-11-09 12:15:47, Disk, Verifying file: H: \ BurnInTest test files \ ~ bittestH00006, size: 762314752, block size: 1048576
                        LOG NOTE: 2012-11-09 12:16:06, Disk, Disk free space: 10181MB, disk size: 14543MB
                        LOG NOTE: 2012-11-09 12:16:06, Disk, Mem Tot: 1851MB [1122MB], page: 3702MB [2827MB], virt: 2047MB [1828MB], ext virt: [0MB], 39
                        LOG NOTE: 2012-11-09 12:16:06, Disk, Writing file: H: \ BurnInTest test files \ ~ bittestH00007, size: 762314752, block size: 1048576
                        LOG NOTE: 2012-11-09 12:16:06, Disk, WriteFile - allocating data buffer: H: \ BurnInTest test files \ ~ bittestH00007
                        LOG NOTE: 2012-11-09 12:16:06, Disk, WriteFile - creating file: H: \ BurnInTest test files \ ~ bittestH00007
                        LOG NOTE: 2012-11-09 12:16:06, Disk, WriteFile - creating data pattern: H: \ BurnInTest test files \ ~ bittestH00007
                        LOG NOTE: 2012-11-09 12:16:06, Disk, WriteFile - write file header: H: \ BurnInTest test files \ ~ bittestH00007
                        LOG NOTE: 2012-11-09 12:16:06, Disk, WriteFile - write file remainder: H: \ BurnInTest test files \ ~ bittestH00007
                        LOG NOTE: 2012-11-09 12:16:32, Disk, WriteFile - leaving: H: \ BurnInTest test files \ ~ bittestH00007
                        LOG NOTE: 2012-11-09 12:16:32, Disk, Verifying file: H: \ BurnInTest test files \ ~ bittestH00007, size: 762314752, block size: 1048576
                        LOG NOTE: 2012-11-09 12:16:51, Disk, Disk free space: 9454MB, disk size: 14543MB
                        LOG NOTE: 2012-11-09 12:16:51, Disk, Mem Tot: 1851MB [1122MB], page: 3702MB [2827MB], virt: 2047MB [1828MB], ext virt: [0MB], 39
                        LOG NOTE: 2012-11-09 12:16:51, Disk, Writing file: H: \ BurnInTest test files \ ~ bittestH00008, size: 762314752, block size: 1048576
                        LOG NOTE: 2012-11-09 12:16:51, Disk, WriteFile - allocating data buffer: H: \ BurnInTest test files \ ~ bittestH00008
                        LOG NOTE: 2012-11-09 12:16:51, Disk, WriteFile - creating file: H: \ BurnInTest test files \ ~ bittestH00008
                        LOG NOTE: 2012-11-09 12:16:51, Disk, WriteFile - creating data pattern: H: \ BurnInTest test files \ ~ bittestH00008
                        LOG NOTE: 2012-11-09 12:16:51, Disk, WriteFile - write file header: H: \ BurnInTest test files \ ~ bittestH00008
                        LOG NOTE: 2012-11-09 12:16:51, Disk, WriteFile - write file remainder: H: \ BurnInTest test files \ ~ bittestH00008
                        LOG NOTE: 2012-11-09 12:17:17, Disk, WriteFile - leaving: H: \ BurnInTest test files \ ~ bittestH00008
                        LOG NOTE: 2012-11-09 12:17:17, Disk, Verifying file: H: \ BurnInTest test files \ ~ bittestH00008, size: 762314752, block size: 1048576
                        LOG NOTE: 2012-11-09 12:17:35, Disk, Disk free space: 8727MB, disk size: 14543MB
                        LOG NOTE: 2012-11-09 12:17:35, Disk, Mem Tot: 1851MB [1122MB], page: 3702MB [2827MB], virt: 2047MB [1828MB], ext virt: [0MB], 39
                        LOG NOTE: 2012-11-09 12:17:35, Disk, Writing file: H: \ BurnInTest test files \ ~ bittestH00009, size: 762314752, block size: 1048576
                        LOG NOTE: 2012-11-09 12:17:35, Disk, WriteFile - allocating data buffer: H: \ BurnInTest test files \ ~ bittestH00009
                        LOG NOTE: 2012-11-09 12:17:35, Disk, WriteFile - creating file: H: \ BurnInTest test files \ ~ bittestH00009
                        LOG NOTE: 2012-11-09 12:17:35, Disk, WriteFile - creating data pattern: H: \ BurnInTest test files \ ~ bittestH00009
                        LOG NOTE: 2012-11-09 12:17:35, Disk, WriteFile - write file header: H: \ BurnInTest test files \ ~ bittestH00009
                        LOG NOTE: 2012-11-09 12:17:36, Disk, WriteFile - write file remainder: H: \ BurnInTest test files \ ~ bittestH00009
                        LOG NOTE: 2012-11-09 12:18:01, Disk, WriteFile - leaving: H: \ BurnInTest test files \ ~ bittestH00009
                        LOG NOTE: 2012-11-09 12:18:01, Disk, Verifying file: H: \ BurnInTest test files \ ~ bittestH00009, size: 762314752, block size: 1048576
                        • Dannycycu
                          • Nov 2012
                          • 34
                          LOG NOTE: 2012-11-09 12:18:20, Disk, Disk free space: 8000MB, disk size: 14543MB
                          LOG NOTE: 2012-11-09 12:18:20, Disk, Mem Tot: 1851MB [1122MB], page: 3702MB [2827MB], virt: 2047MB [1828MB], ext virt: [0MB], 39
                          LOG NOTE: 2012-11-09 12:18:20, Disk, Writing file: H: \ BurnInTest test files \ ~ bittestH00010, size: 762314752, block size: 1048576
                          LOG NOTE: 2012-11-09 12:18:20, Disk, WriteFile - allocating data buffer: H: \ BurnInTest test files \ ~ bittestH00010
                          LOG NOTE: 2012-11-09 12:18:20, Disk, WriteFile - creating file: H: \ BurnInTest test files \ ~ bittestH00010
                          LOG NOTE: 2012-11-09 12:18:20, Disk, WriteFile - creating data pattern: H: \ BurnInTest test files \ ~ bittestH00010
                          LOG NOTE: 2012-11-09 12:18:20, Disk, WriteFile - write file header: H: \ BurnInTest test files \ ~ bittestH00010
                          LOG NOTE: 2012-11-09 12:18:20, Disk, WriteFile - write file remainder: H: \ BurnInTest test files \ ~ bittestH00010
                          LOG NOTE: 2012-11-09 12:18:46, Disk, WriteFile - leaving: H: \ BurnInTest test files \ ~ bittestH00010
                          LOG NOTE: 2012-11-09 12:18:46, Disk, Verifying file: H: \ BurnInTest test files \ ~ bittestH00010, size: 762314752, block size: 1048576
                          LOG NOTE: 2012-11-09 12:19:05, Disk, Disk free space: 7273MB, disk size: 14543MB
                          LOG NOTE: 2012-11-09 12:19:05, Disk, Mem Tot: 1851MB [1122MB], page: 3702MB [2827MB], virt: 2047MB [1828MB], ext virt: [0MB], 39
                          LOG NOTE: 2012-11-09 12:19:05, Disk, Writing file: H: \ BurnInTest test files \ ~ bittestH00011, size: 762314752, block size: 1048576
                          LOG NOTE: 2012-11-09 12:19:05, Disk, WriteFile - allocating data buffer: H: \ BurnInTest test files \ ~ bittestH00011
                          LOG NOTE: 2012-11-09 12:19:05, Disk, WriteFile - creating file: H: \ BurnInTest test files \ ~ bittestH00011
                          LOG NOTE: 2012-11-09 12:19:05, Disk, WriteFile - creating data pattern: H: \ BurnInTest test files \ ~ bittestH00011
                          LOG NOTE: 2012-11-09 12:19:05, Disk, WriteFile - write file header: H: \ BurnInTest test files \ ~ bittestH00011
                          LOG NOTE: 2012-11-09 12:19:05, Disk, WriteFile - write file remainder: H: \ BurnInTest test files \ ~ bittestH00011
                          LOG NOTE: 2012-11-09 12:19:31, Disk, WriteFile - leaving: H: \ BurnInTest test files \ ~ bittestH00011
                          LOG NOTE: 2012-11-09 12:19:31, Disk, Verifying file: H: \ BurnInTest test files \ ~ bittestH00011, size: 762314752, block size: 1048576
                          LOG NOTE: 2012-11-09 12:19:49, Disk, Disk free space: 6546MB, disk size: 14543MB
                          LOG NOTE: 2012-11-09 12:19:49, Disk, Mem Tot: 1851MB [1122MB], page: 3702MB [2827MB], virt: 2047MB [1828MB], ext virt: [0MB], 39
                          LOG NOTE: 2012-11-09 12:19:49, Disk, Writing file: H: \ BurnInTest test files \ ~ bittestH00012, size: 762314752, block size: 1048576
                          LOG NOTE: 2012-11-09 12:19:49, Disk, WriteFile - allocating data buffer: H: \ BurnInTest test files \ ~ bittestH00012
                          LOG NOTE: 2012-11-09 12:19:49, Disk, WriteFile - creating file: H: \ BurnInTest test files \ ~ bittestH00012
                          LOG NOTE: 2012-11-09 12:19:49, Disk, WriteFile - creating data pattern: H: \ BurnInTest test files \ ~ bittestH00012
                          LOG NOTE: 2012-11-09 12:19:49, Disk, WriteFile - write file header: H: \ BurnInTest test files \ ~ bittestH00012
                          LOG NOTE: 2012-11-09 12:19:50, Disk, WriteFile - write file remainder: H: \ BurnInTest test files \ ~ bittestH00012
                          LOG NOTE: 2012-11-09 12:20:16, Disk, WriteFile - leaving: H: \ BurnInTest test files \ ~ bittestH00012
                          LOG NOTE: 2012-11-09 12:20:16, Disk, Verifying file: H: \ BurnInTest test files \ ~ bittestH00012, size: 762314752, block size: 1048576
                          LOG NOTE: 2012-11-09 12:20:35, Disk, Disk free space: 5819MB, disk size: 14543MB
                          LOG NOTE: 2012-11-09 12:20:35, Disk, Mem Tot: 1851MB [1123MB], page: 3702MB [2827MB], virt: 2047MB [1828MB], ext virt: [0MB], 39
                          LOG NOTE: 2012-11-09 12:20:35, Disk, Writing file: H: \ BurnInTest test files \ ~ bittestH00013, size: 762314752, block size: 1048576
                          LOG NOTE: 2012-11-09 12:20:35, Disk, WriteFile - allocating data buffer: H: \ BurnInTest test files \ ~ bittestH00013
                          LOG NOTE: 2012-11-09 12:20:35, Disk, WriteFile - creating file: H: \ BurnInTest test files \ ~ bittestH00013
                          LOG NOTE: 2012-11-09 12:20:35, Disk, WriteFile - creating data pattern: H: \ BurnInTest test files \ ~ bittestH00013
                          LOG NOTE: 2012-11-09 12:20:35, Disk, WriteFile - write file header: H: \ BurnInTest test files \ ~ bittestH00013
                          LOG NOTE: 2012-11-09 12:20:35, Disk, WriteFile - write file remainder: H: \ BurnInTest test files \ ~ bittestH00013
                          LOG NOTE: 2012-11-09 12:21:00, Disk, WriteFile - leaving: H: \ BurnInTest test files \ ~ bittestH00013
                          LOG NOTE: 2012-11-09 12:21:00, Disk, Verifying file: H: \ BurnInTest test files \ ~ bittestH00013, size: 762314752, block size: 1048576
                          LOG NOTE: 2012-11-09 12:21:19, Disk, Disk free space: 5092MB, disk size: 14543MB
                          LOG NOTE: 2012-11-09 12:21:19, Disk, Mem Tot: 1851MB [1123MB], page: 3702MB [2827MB], virt: 2047MB [1828MB], ext virt: [0MB], 39
                          LOG NOTE: 2012-11-09 12:21:19, Disk, Writing file: H: \ BurnInTest test files \ ~ bittestH00014, size: 762314752, block size: 1048576
                          LOG NOTE: 2012-11-09 12:21:19, Disk, WriteFile - allocating data buffer: H: \ BurnInTest test files \ ~ bittestH00014
                          LOG NOTE: 2012-11-09 12:21:19, Disk, WriteFile - creating file: H: \ BurnInTest test files \ ~ bittestH00014
                          LOG NOTE: 2012-11-09 12:21:19, Disk, WriteFile - creating data pattern: H: \ BurnInTest test files \ ~ bittestH00014
                          LOG NOTE: 2012-11-09 12:21:19, Disk, WriteFile - write file header: H: \ BurnInTest test files \ ~ bittestH00014
                          LOG NOTE: 2012-11-09 12:21:19, Disk, WriteFile - write file remainder: H: \ BurnInTest test files \ ~ bittestH00014
                          LOG NOTE: 2012-11-09 12:21:45, Disk, WriteFile - leaving: H: \ BurnInTest test files \ ~ bittestH00014
                          LOG NOTE: 2012-11-09 12:21:45, Disk, Verifying file: H: \ BurnInTest test files \ ~ bittestH00014, size: 762314752, block size: 1048576
                          LOG NOTE: 2012-11-09 12:22:04, Disk, Disk free space: 4365MB, disk size: 14543MB
                          LOG NOTE: 2012-11-09 12:22:04, Disk, Mem Tot: 1851MB [1124MB], page: 3702MB [2827MB], virt: 2047MB [1828MB], ext virt: [0MB], 39
                          LOG NOTE: 2012-11-09 12:22:04, Disk, Writing file: H: \ BurnInTest test files \ ~ bittestH00015, size: 762314752, block size: 1048576
                          LOG NOTE: 2012-11-09 12:22:04, Disk, WriteFile - allocating data buffer: H: \ BurnInTest test files \ ~ bittestH00015
                          LOG NOTE: 2012-11-09 12:22:04, Disk, WriteFile - creating file: H: \ BurnInTest test files \ ~ bittestH00015
                          LOG NOTE: 2012-11-09 12:22:04, Disk, WriteFile - creating data pattern: H: \ BurnInTest test files \ ~ bittestH00015
                          LOG NOTE: 2012-11-09 12:22:04, Disk, WriteFile - write file header: H: \ BurnInTest test files \ ~ bittestH00015
                          LOG NOTE: 2012-11-09 12:22:04, Disk, WriteFile - write file remainder: H: \ BurnInTest test files \ ~ bittestH00015
                          LOG NOTE: 2012-11-09 12:22:30, Disk, WriteFile - leaving: H: \ BurnInTest test files \ ~ bittestH00015
                          LOG NOTE: 2012-11-09 12:22:30, Disk, Verifying file: H: \ BurnInTest test files \ ~ bittestH00015, size: 762314752, block size: 1048576
                          LOG NOTE: 2012-11-09 12:22:49, Disk, Disk free space: 3638MB, disk size: 14543MB
                          LOG NOTE: 2012-11-09 12:22:49, Disk, Mem Tot: 1851MB [1124MB], page: 3702MB [2827MB], virt: 2047MB [1828MB], ext virt: [0MB], 39
                          LOG NOTE: 2012-11-09 12:22:49, Disk, Writing file: H: \ BurnInTest test files \ ~ bittestH00016, size: 762314752, block size: 1048576
                          LOG NOTE: 2012-11-09 12:22:49, Disk, WriteFile - allocating data buffer: H: \ BurnInTest test files \ ~ bittestH00016
                          LOG NOTE: 2012-11-09 12:22:49, Disk, WriteFile - creating file: H: \ BurnInTest test files \ ~ bittestH00016
                          LOG NOTE: 2012-11-09 12:22:49, Disk, WriteFile - creating data pattern: H: \ BurnInTest test files \ ~ bittestH00016
                          LOG NOTE: 2012-11-09 12:22:49, Disk, WriteFile - write file header: H: \ BurnInTest test files \ ~ bittestH00016
                          LOG NOTE: 2012-11-09 12:22:49, Disk, WriteFile - write file remainder: H: \ BurnInTest test files \ ~ bittestH00016
                          LOG NOTE: 2012-11-09 12:23:15, Disk, WriteFile - leaving: H: \ BurnInTest test files \ ~ bittestH00016
                          LOG NOTE: 2012-11-09 12:23:15, Disk, Verifying file: H: \ BurnInTest test files \ ~ bittestH00016, size: 762314752, block size: 1048576
                          LOG NOTE: 2012-11-09 12:23:34, Disk, Disk free space: 2911MB, disk size: 14543MB
                          LOG NOTE: 2012-11-09 12:23:34, Disk, Mem Tot: 1851MB [1124MB], page: 3702MB [2827MB], virt: 2047MB [1828MB], ext virt: [0MB], 39
                          LOG NOTE: 2012-11-09 12:23:34, Disk, Writing file: H: \ BurnInTest test files \ ~ bittestH00017, size: 762314752, block size: 1048576
                          LOG NOTE: 2012-11-09 12:23:34, Disk, WriteFile - allocating data buffer: H: \ BurnInTest test files \ ~ bittestH00017
                          LOG NOTE: 2012-11-09 12:23:34, Disk, WriteFile - creating file: H: \ BurnInTest test files \ ~ bittestH00017
                          LOG NOTE: 2012-11-09 12:23:34, Disk, WriteFile - creating data pattern: H: \ BurnInTest test files \ ~ bittestH00017
                          LOG NOTE: 2012-11-09 12:23:34, Disk, WriteFile - write file header: H: \ BurnInTest test files \ ~ bittestH00017
                          LOG NOTE: 2012-11-09 12:23:34, Disk, WriteFile - write file remainder: H: \ BurnInTest test files \ ~ bittestH00017
                          LOG NOTE: 2012-11-09 12:24:00, Disk, WriteFile - leaving: H: \ BurnInTest test files \ ~ bittestH00017
                          LOG NOTE: 2012-11-09 12:24:00, Disk, Verifying file: H: \ BurnInTest test files \ ~ bittestH00017, size: 762314752, block size: 1048576
                          LOG NOTE: 2012-11-09 12:24:18, Disk, Disk free space: 2184MB, disk size: 14543MB
                          LOG NOTE: 2012-11-09 12:24:18, Disk, Mem Tot: 1851MB [1124MB], page: 3702MB [2827MB], virt: 2047MB [1828MB], ext virt: [0MB], 39
                          LOG NOTE: 2012-11-09 12:24:18, Disk, Writing file: H: \ BurnInTest test files \ ~ bittestH00018, size: 762314752, block size: 1048576
                          LOG NOTE: 2012-11-09 12:24:18, Disk, WriteFile - allocating data buffer: H: \ BurnInTest test files \ ~ bittestH00018
                          LOG NOTE: 2012-11-09 12:24:18, Disk, WriteFile - creating file: H: \ BurnInTest test files \ ~ bittestH00018
                          LOG NOTE: 2012-11-09 12:24:18, Disk, WriteFile - creating data pattern: H: \ BurnInTest test files \ ~ bittestH00018
                          LOG NOTE: 2012-11-09 12:24:18, Disk, WriteFile - write file header: H: \ BurnInTest test files \ ~ bittestH00018
                          LOG NOTE: 2012-11-09 12:24:19, Disk, WriteFile - write file remainder: H: \ BurnInTest test files \ ~ bittestH00018
                          LOG NOTE: 2012-11-09 12:24:44, Disk, WriteFile - leaving: H: \ BurnInTest test files \ ~ bittestH00018
                          LOG NOTE: 2012-11-09 12:24:44, Disk, Verifying file: H: \ BurnInTest test files \ ~ bittestH00018, size: 762314752, block size: 1048576
                          LOG NOTE: 2012-11-09 12:25:03, Disk, Disk free space: 1457MB, disk size: 14543MB
                          LOG NOTE: 2012-11-09 12:25:03, Disk, Mem Tot: 1851MB [1124MB], page: 3702MB [2827MB], virt: 2047MB [1828MB], ext virt: [0MB], 39
                          LOG NOTE: 2012-11-09 12:25:03, Disk, Writing file: H: \ BurnInTest test files \ ~ bittestH00019, size: 762314752, block size: 1048576
                          LOG NOTE: 2012-11-09 12:25:03, Disk, WriteFile - allocating data buffer: H: \ BurnInTest test files \ ~ bittestH00019
                          LOG NOTE: 2012-11-09 12:25:03, Disk, WriteFile - creating file: H: \ BurnInTest test files \ ~ bittestH00019
                          LOG NOTE: 2012-11-09 12:25:03, Disk, WriteFile - creating data pattern: H: \ BurnInTest test files \ ~ bittestH00019
                          LOG NOTE: 2012-11-09 12:25:03, Disk, WriteFile - write file header: H: \ BurnInTest test files \ ~ bittestH00019
                          LOG NOTE: 2012-11-09 12:25:03, Disk, WriteFile - write file remainder: H: \ BurnInTest test files \ ~ bittestH00019
                          LOG NOTE: 2012-11-09 12:25:29, Disk, WriteFile - leaving: H: \ BurnInTest test files \ ~ bittestH00019
                          LOG NOTE: 2012-11-09 12:25:29, Disk, Verifying file: H: \ BurnInTest test files \ ~ bittestH00019, size: 762314752, block size: 1048576
                          LOG NOTE: 2012-11-09 12:25:48, Disk, Disk free space: 730MB, disk size: 14543MB
                          LOG NOTE: 2012-11-09 12:25:48, Disk, Mem Tot: 1851MB [1124MB], page: 3702MB [2827MB], virt: 2047MB [1828MB], ext virt: [0MB], 39
                          LOG NOTE: 2012-11-09 12:25:48, Disk, Disk full detected: 730MB (14543MB)
                          LOG NOTE: 2012-11-09 12:26:08, Disk, [H:] Deleted 19 test files
                          LOG NOTE: 2012-11-09 12:26:08, Disk, Writing file: H: \ BurnInTest test files \ ~ bittestH00001, size: 762314752, block size: 1048576
                          LOG NOTE: 2012-11-09 12:26:08, Disk, WriteFile - allocating data buffer: H: \ BurnInTest test files \ ~ bittestH00001
                          LOG NOTE: 2012-11-09 12:26:08, Disk, WriteFile - creating file: H: \ BurnInTest test files \ ~ bittestH00001
                          LOG NOTE: 2012-11-09 12:26:08, Disk, WriteFile - creating data pattern: H: \ BurnInTest test files \ ~ bittestH00001
                          LOG NOTE: 2012-11-09 12:26:08, Disk, WriteFile - write file header: H: \ BurnInTest test files \ ~ bittestH00001
                          LOG NOTE: 2012-11-09 12:26:08, StopTests [3]
                          LOG NOTE: 2012-11-09 12:26:08, Test run stopping - step 0.0. 0: 0 of 1
                          LOG NOTE: 2012-11-09 12:26:09, Disk, WriteFile - write file remainder: H: \ BurnInTest test files \ ~ bittestH00001
                          LOG NOTE: 2012-11-09 12:26:12, Disk, WriteFile - leaving: H: \ BurnInTest test files \ ~ bittestH00001
                          LOG NOTE: 2012-11-09 12:26:12, Disk, [H:] Deleted 1 test files
                          LOG NOTE: 2012-11-09 12:26:12, Disk (H : ), Stopping test
                          LOG NOTE: 2012-11-09 12:26:14, Status, Test run stopped
                          • Dannycycu
                            • Nov 2012
                            • 34
                            Fail level 2 activity trace log:
                            LOG NOTE: 2012-11-07 15:17:08, Scripting on stop interim, errors = 0
                            LOG NOTE: 2012-11-07 15:17:13, Script, SETCYCLES 1
                            LOG NOTE: 2012-11-07 15:17:13, Script, SETDURATION 0
                            LOG NOTE: 2012-11-07 15:17:13, Script, SETDISK DISK H: MODE butterfly FILE 5 BLOCK 1024 SEEK 100
                            LOG NOTE: 2012-11-07 15:17:13, Script, RUN DISK
                            LOG NOTE: 2012-11-07 15:17:13, StartTests
                            LOG NOTE: 2012-11-07 15:17:14, Status, Main Tests started
                            LOG NOTE: 2012-11-07 15:17:14, Perform test: Disk (H : ) at 100%
                            LOG NOTE: 2012-11-07 15:17:14, Disk (H : ), Starting test
                            LOG NOTE: 2012-11-07 15:17:15, Disk paging file: H 1
                            LOG NOTE: 2012-11-07 15:17:15, Disk paging file B: HC
                            LOG NOTE: 2012-11-07 15:17:15, Disk Win install: HC
                            LOG NOTE: 2012-11-07 15:17:15, Disk, Disk free space: 14543MB, disk size: 14543MB
                            LOG NOTE: 2012-11-07 15:17:15, Disk, GetVolumeExtents: Drive H: \, Volume: \ \? \ Volume {b0148906-0c62-11e2-8e97-6cf049daeb28}
                            LOG NOTE: 2012-11-07 15:17:15, Disk, GetVolumeExtents: IOCTL_VOLUME_GET_VOLUME_DISK_EXTENTS success
                            LOG NOTE: 2012-11-07 15:17:15, Disk, GetVolumeExtents: IOCTL_VOLUME_GET_VOLUME_DISK_EXTENTS data returned 32
                            LOG NOTE: 2012-11-07 15:17:15, Disk, GetDriveGeometry: Drive H: (0 of 1 extents)
                            LOG NOTE: 2012-11-07 15:17:15, Disk, GetDriveGeometry: Open \ \. \ PhysicalDrive2
                            LOG NOTE: 2012-11-07 15:17:15, Disk, GetDriveGeometry Ex: Query Device driver
                            LOG NOTE: 2012-11-07 15:17:15, Disk, GetDriveGeometry: Drive H: (Extent size: 15267234304, Tracks / C: (255), Sectors / T: (63), Bytes / S: (512)
                            LOG NOTE: 2012-11-07 15:31:13, Disk, GetVolumeExtents: Drive H: \, Volume: \ \? \ Volume {b0148906-0c62-11e2-8e97-6cf049daeb28}
                            LOG NOTE: 2012-11-07 15:31:13, Disk, GetVolumeExtents: IOCTL_VOLUME_GET_VOLUME_DISK_EXTENTS success
                            LOG NOTE: 2012-11-07 15:31:13, Disk, GetVolumeExtents: IOCTL_VOLUME_GET_VOLUME_DISK_EXTENTS data returned 32
                            LOG NOTE: 2012-11-07 15:31:13, Disk, GetDriveGeometry: Drive H: (0 of 1 extents)
                            LOG NOTE: 2012-11-07 15:31:13, Disk, GetDriveGeometry: Open \ \. \ PhysicalDrive2
                            LOG NOTE: 2012-11-07 15:31:13, Disk, GetDriveGeometry Ex: Query Device driver
                            LOG NOTE: 2012-11-07 15:31:13, Disk, GetDriveGeometry: Drive H: (Extent size: 15267234304, Tracks / C: (255), Sectors / T: (63), Bytes / S: (512)
                            LOG NOTE: 2012-11-07 15:31:14, StopTests [3]
                            LOG NOTE: 2012-11-07 15:31:14, Test run stopping - step 0.0. 0: 0 of 1
                            LOG NOTE: 2012-11-07 15:31:17, Disk (H : ), Stopping test
                            LOG NOTE: 2012-11-07 15:31:19, Status, Test run stopped
                            LOG NOTE: 2012-11-07 15:31:20, Scripting on stop interim, errors = 0
                            LOG NOTE: 2012-11-07 15:31:25, Script, SETCYCLES 19
                            LOG NOTE: 2012-11-07 15:31:25, Script, SETDURATION 0
                            LOG NOTE: 2012-11-07 15:31:25, Script, SETDISK DISK H: MODE binary1 FILE 5 BLOCK 1024 SEEK 100
                            LOG NOTE: 2012-11-07 15:31:25, Script, RUN DISK
                            LOG NOTE: 2012-11-07 15:31:25, StartTests
                            LOG NOTE: 2012-11-07 15:31:26, Status, Main Tests started
                            LOG NOTE: 2012-11-07 15:31:26, Perform test: Disk (H : ) at 100%
                            LOG NOTE: 2012-11-07 15:31:26, Disk (H : ), Starting test
                            LOG NOTE: 2012-11-07 15:31:27, Disk paging file: H 1
                            LOG NOTE: 2012-11-07 15:31:27, Disk paging file B: HC
                            LOG NOTE: 2012-11-07 15:31:27, Disk Win install: HC
                            LOG NOTE: 2012-11-07 15:31:27, Disk, Disk free space: 14543MB, disk size: 14543MB
                            LOG NOTE: 2012-11-07 15:31:27, Disk, Writing file: H: \ BurnInTest test files \ ~ bittestH00001, size: 762314752, block size: 1048576
                            LOG NOTE: 2012-11-07 15:31:27, Disk, WriteFile - allocating data buffer: H: \ BurnInTest test files \ ~ bittestH00001
                            LOG NOTE: 2012-11-07 15:31:27, Disk, WriteFile - creating file: H: \ BurnInTest test files \ ~ bittestH00001
                            WARNING: 2012-11-07 15:31:32, Disk, H: Test file could not be created. Check access privileges.
                            LOG NOTE: 2012-11-07 15:31:32, Disk, Write File - File name: H: \ BurnInTest test files \ ~ bittestH00001
                            LOG NOTE: 2012-11-07 15:31:32, Disk, The request could not be performed because of an I/O device error. (1117)
                            LOG NOTE: 2012-11-07 15:31:32, Disk, Error writing file: H: \ BurnInTest test files \ ~ bittestH00001, size: 762314752, blocksize 1048576
                            LOG NOTE: 2012-11-07 15:31:32, StopTests [4]
                            LOG NOTE: 2012-11-07 15:31:32, Test run stopping - step 0.0. 0: 0 of 1
                            LOG NOTE: 2012-11-07 15:31:38, Disk, Disk free space: 14543MB, disk size: 14543MB
                            LOG NOTE: 2012-11-07 15:31:38, Disk, Mem Tot: 1851MB [1241MB], page: 3702MB [2912MB], virt: 2047MB [1824MB], ext virt: [0MB], 32
                            LOG NOTE: 2012-11-07 15:31:38, Disk, Disk Error (H : ): Test file could not be created. Check access privileges. In Cycle 0 with pattern Binary data pattern 1 (1010)
                            LOG NOTE: 2012-11-07 15:31:42, Status, Test run stopped
                            what difference between pass level 2 activity trace log and fail level 2 activity trace log?
                            ​Thanks!
                              One had a failure and the other one didn't.
                              We can't wave a magic wand and tell you why your hardware (which we have no access to) is failing.
